Scale Model Engineering Steam, gas and hot air model engines, tractors and accessories. Machining and milling castings.
Perkins engine , spark plug problem
this thread has 5 replies and has been viewed 598 times
Old 01-30-2019, 12:31:10 PM
Tom Jamboretz's Avatar
Tom Jamboretz Tom Jamboretz is offline
Default Perkins engine , spark plug problem
I have just completed a Perkins engine build. It is the horizontal open crank type. The engines craps out. When I check the spark plug i find that it is sparking up inside of the plug and not at the electrodes. I clean the plug and it does the same thing again. It only runs about 1-2 minutes. I'm running it on regular gasoline with a buzz coil. Would appreciate any help. Thanks
Old 01-30-2019, 01:22:25 PM
Default Re: Perkins engine , spark plug problem
Replace the plug. new gas shorts under compression, and once that happens, it will continue. You cab try heating the plug with a propane torch until the carbon and gas are burned off - don't know if that will work or not. Just hitting it with solvent won't do it.
Old 01-30-2019, 09:21:50 PM
Jesse Zilafro Jesse Zilafro is offline
Tom put some wd40 in the plug and close the gap down some. And use cloeman gass.
Old 01-31-2019, 12:59:55 AM
dkamp dkamp is offline
eMail NOT Working
Champion plug?
Old 03-06-2019, 06:11:49 PM
Exclamation Re: Perkins engine , spark plug problem
Quite often, model engines just idle along with no load. The spark plug does not get hot enough to burn off carbon deposits, therefore they foul plugs. Short of haeting with a torch, you cannot clean all of the gunk out of the plug. if it is a home made plug, made of high temperature plastic or teflon, your only choice is to replace it. Once they short, as yours is doing, they are done unless you can heat them up hot enough to burn off the deposits. You cant do that with the plastic pugs. Colemans may help, but only if you have a good plug to begin with. A fouled plug simply will not work.
Old 03-14-2019, 03:40:04 PM
crazydoug crazydoug is offline
I sand blast fouled plugs and they seem to work fine again. You do have to make sure and get any little grains of sand stuck around the insulator out, or they could end up in the cylinder.
Has anyone else tried this- is it not a good idea for some reason?
crazydoug
I have that same engine and it fouled plugs alot till i cut back on the fuel as much as possible.
The Following User Says Thank You to crazydoug For This Post:
Mag or spark plug causing the problem? IWL BCNU Antique Gas Engine Discussion 6 01-29-2015 08:12:11 AM
Fairbanks Morse Z 1 1/2 hp Spark Plug problem thiggy Antique Gas Engine Discussion 5 09-19-2013 10:51:21 PM
Which spark plug for an IHC M engine? JohnCCarlson Magnetos, Ignition Coils and Spark Plugs 1 06-19-2009 07:50:58 AM
Halfbreed spark plug problem Frank Stenger Oil Field Engines & Related Equipment 16 09-07-2007 10:36:20 AM
Spark plug problem Al Hettich Antique Engine Archives 8 07-23-2002 08:52:19 PM
