Scale Model Engineering Steam, gas and hot air model engines, tractors and accessories. Machining and milling castings.
Old Victrola speed governor
this thread has 4 replies and has been viewed 470 times
Old 02-03-2019, 10:01:45 PM
Default Old Victrola speed governor
found at the “FLEA” market the other day. It’s operational , and would make a good governor for a future gas or steam engine model project . Anybody have any other ideas for a project using this governor, or have used one in a project .
Name:	Victrola Governor.jpg
Make a new friend today, and a lot on the way through . Paul-"OLDIHC" #227
My YouTube channel : https://www.youtube.com/user/njoldihc
Old 02-04-2019, 02:49:06 PM
Default Re: Old Victrola speed governor
There is a similar one hooked up to my vertical tandem Sipp engine. Unfortunately, some @#$%%^^&&*(( Bas---D stole the linkages and throttling valve before I purchased the engine. it had run 5 sewing machines in NYC back in the late 1890s. The guy I bought it from had it and 2otherengines for sale at a garage sale, and the robber stole most of the brass parts out of all 3 engines before someone noticed what he ws doing.
Old 02-04-2019, 06:03:37 PM
ronm ronm is offline
I took the mechanism out of an old Victrola when I was a kid. Played with the governor until I figured out how it worked, (friction), & figured out how to make it run a LOT faster than it should...after a minute or so, one weight broke off & hit me right in my eyebrow. It came off with part of the leaf spring attached, & cut the crap out of my eyebrow, right above the eyelid, & it bled like hell...an inch lower & I would have been a one-eyed kid. Never told my Mom what happened...
So be careful with it, it's not a real high-speed unit.
Smokstak member #442
Old 02-04-2019, 07:49:26 PM
Barnbikes Barnbikes is offline
I saw a youtube video of a hotair powered record player a while back. It sure could be a start of something fun.
The Following User Says Thank You to Barnbikes For This Post:
Old 02-04-2019, 10:45:04 PM
Junkologist's Avatar
Images: 160
I was perusing a local antique mall yesterday and saw a model boat that was powered by a Victrola spring motor. I thought that was a pretty clever idea.
Mike
SmokStak member #146
Speed Governor Jim Marcozzi Onan Generators 7 10-17-2018 12:41:49 PM
12.5JC L - Locating the governor speed adjustment - help wstefanc Onan Generators 10 09-11-2018 11:15:43 PM
Maytag 92-Governor speed control ? scott5353 Antique Gas Engine Discussion 1 06-15-2015 07:19:41 AM
Box of Turntable parts Victrola? Jim Martin Farm + Industrial Antiques and Collectibles 0 05-24-2015 12:55:54 PM
Judson Governor Speed LarryT Steam Stationary Engines, Traction Engines, Steam Boats 15 04-23-2014 08:19:48 PM
