Kohler Generators
need information on Kohler Generator 45RZ82
this thread has 6 replies and has been viewed 255 times
Old 02-23-2019, 03:28:22 PM
gsw gsw is offline
Default need information on Kohler Generator 45RZ82
I own a kohler 45rz82 serial 363954,spec pa-183238-82N it is natural gas and has engine csg-6491-6005-f. It has a outdoor cover. The muffler/silencer has gone bad and I need a new one. I do not have a parts manual does anyone know where I can get a manual or the part number for the muffler and where I might find the muffler?Click image for larger version
ID:	329260Click image for larger version
Old 02-23-2019, 04:59:05 PM
Email NOT Working
Default Re: need information on Kohler Generator 45RZ82
If you can even find this part in the Kohler system it is likely to be extremely expensive and take forever if you can get it at all.
Instead, call around for exhaust system suppliers in your area. Probably it will have to be custom built but if you find the right rep they can make anything for you.
But you might try Kohler first, they may surprise you.
Old 02-25-2019, 08:47:20 AM
gsw gsw is offline
I have found the part at local Kohler distributor and your right its expensive. For everything its over a thousand. I have the part number its C5TZ-5230-C any help locating one used or less expensive would be greatly appreciated. Also I have seen some similar units that have been modified and look to have a tractor muffler, do you think this may work?
Old 02-25-2019, 09:03:14 AM
Tracy T Tracy T is offline
any muffler will work, however it may not be as quiet or last as long. two key things come to mind, keeping rain water out of the exhaust and cracking the manifold due to vibration. i would try to modify something that is as close to the orignal design as possible. geesh a grand for a muffler........
Old 02-25-2019, 10:38:01 AM
Email NOT Working
I have seen a lot of cobbled together mufflers and they all stink. Maybe it is worth it to just pay the big bucks and get one that just fits and is quiet and keeps the water out.
Old 02-25-2019, 11:23:40 AM
i googled that part number and came up with a ford truck muffler? if you gave the dimensions etc to somebody like walker i bet they could hook you up with a direct replacement.
Old 02-25-2019, 01:40:43 PM
Zephyr7 Zephyr7 is offline
Most of these mufflers arenít very complicated in their construction. If your old one is still together enough for you to see how itís built, you could probably get a welding or metal shop to make a copy for you with new materials. That might be an option for you if you canít find a suitable unit to buy.
Bill
Kohler 45RZ82 Questions d6btex Kohler Generators 2 02-19-2015 09:24:19 PM
45RZ82 with Ford CSG649 engine OnanSupervisor Kohler Generators 1 09-18-2014 05:15:51 PM
Kohler 3.5RM62 Spec. 620 H.3.4.5.7 with kohler A-23858 information bobfish1 Kohler Generators 2 08-13-2013 10:21:18 AM
Kohler with Waukesha & Big Generator Information needed (5E61) Jim Martin Generators & Electric Motors General Discussion 5 07-02-2012 01:41:13 PM
Information on Kohler Model 1M21 generator? JerryK Kohler Generators 1 02-28-2005 05:11:54 AM
