Scale Model Engineering Steam, gas and hot air model engines, tractors and accessories. Machining and milling castings.
unknown boiler
this thread has 1 replies and has been viewed 267 times
Old 02-23-2019, 09:53:05 PM
stevenkd5017 stevenkd5017 is online now
Default unknown boiler
Picked this boiler up at an auction today. I'm just getting started with steam models I have have some gas engine models, but I don't know much about steam or how it goes together. This boiler overall is 10.5 inches long by about 6.5 inches high, 10.5 inches high to the top of the stack. The boiler itself is about 3.5" in diameter and 9 inches long. It looks like this might have gone into something larger like a model building or something and the top of the boiler has some kind of filler similar to concrete. It does not seem to be a homemade model It seems like it might have a couple of safety valves one on the top and one on the bottom of the tube under the sight glass. It has no gauge or fitting to connect to an engine, I believe the threaded hole on the top would be for the connection to the engine, could you also tee a gauge off of that?
ID:	329270   Click image for larger version
ID:	329271   Click image for larger version
ID:	329272   Click image for larger version
ID:	329273   Click image for larger version
Old 02-23-2019, 11:11:21 PM
ulgydog56's Avatar
Default Re: unknown boiler
don't know but it looks like a scotch marine design boiler, very different very cool...
Unknown Boiler and steam engine. Lester Bowman Scale Model Engineering 10 09-01-2017 05:20:30 PM
Unknown Boiler steveplutt Steam Stationary Engines, Traction Engines, Steam Boats 3 03-09-2015 07:20:28 AM
Unknown Boiler steveplutt Smokstak Forums Meet and Greet 2 03-08-2015 12:41:19 PM
Unknown Vertical Boiler Question todengine Steam Stationary Engines, Traction Engines, Steam Boats 9 03-29-2014 04:14:35 PM
Unknown boiler Clark Bigger Steam Stationary Engines, Traction Engines, Steam Boats 3 03-12-2008 12:24:23 AM
