Scale Model Engineering Steam, gas and hot air model engines, tractors and accessories. Machining and milling castings.
model domestic vertical internal points question
this thread has 4 replies and has been viewed 315 times
Old 02-28-2019, 08:55:19 AM
crazydoug crazydoug is offline
Default model domestic vertical internal points question
I have completed a model domestic vertical engine build and am having a problem with the internal points assembly.
The stationary contact requires an insulator bushing. What do you make this bushing out of and where do you get this material? I tried making it out of Delrin, and it melted. I have built other model engines, but they all had spark plugs. I would just give up and convert this to a spark plug, but would prefer to keep it original to the bluprints.
It was built from one of Bob Herder's casting sets, so may be calling Bob tonight!
Thanks in advance for any help
crazydoug
Old 02-28-2019, 09:13:05 AM
BobHerder BobHerder is offline
Default Re: model domestic vertical internal points question
Hi give me a call after 5 Bob Herder
Old 02-28-2019, 10:08:21 AM
Thanks Bob, i'll do that- hated to bother you if not necessary.
doug
Old 02-28-2019, 11:54:09 AM
Kynar may work.Its higher temp. rated.
Old 02-28-2019, 08:32:39 PM
Thanks!
Generator Internal Paint Question s100 Generators & Electric Motors General Discussion 8 12-05-2017 09:32:00 PM
Vertical Domestic model help needed George Best Scale Model Engineering 3 06-28-2016 06:26:25 AM
1979 3W091A Dayton/Onan generator internal wiring question archangel Onan Generators 11 04-07-2016 08:38:20 AM
Ideal Vertical Model M 2-1/2 hp - bracket question Heavy Metal Antique Gas Engine Discussion 13 11-05-2014 08:32:31 AM
Vertical Domestic Model Problems Grp4 Scale Model Engineering 5 05-25-2009 08:56:13 PM
