Kohler Generators
Kohler G2001 PTO Generator for troybilt tiller
this thread has 7 replies and has been viewed 369 times
Old 03-01-2019, 07:55:31 PM
Mike26711 Mike26711 is offline
Exclamation Kohler G2001 PTO Generator for troybilt tiller
This is my first post I was wandering if anyone have any info on these units. I have attached a picture of the data plate and installed unit. I also snapped a pic of the regulator numbers. I believe kohler made these for Troy bilt. It took me awhile to find one and it worked great until a few weeks ago during a power outage I ran it for 4hrs under light load. Went to use next morning kicked it in and nothing first thing I noticed was hz gauge wasnít working, and checked and had no voltage. I verified proper engine speed, PTO operation. The generator is spinning. Any help would be appreciated.
Kohler G2001, serial#225825; spec11507. 2.6kw
ID:	329685   Click image for larger version
ID:	329686   Click image for larger version
Old 03-01-2019, 08:07:48 PM
Default Re: Kohler G2001 PTO Generator for troybilt tiller
If it was mine, I would carefully check for loose or corroded connections etc.
For what it is worth, that B-239311 regulator is costly to replace. The last one I priced (did not buy) was over $600.
Old 03-01-2019, 09:03:51 PM
I checked all connections inside and they looks tight, brushes are clean. Also checked an inline fuse and it was good. I rechecked voltage and it was outputting 4v ac.
Old 03-01-2019, 09:43:02 PM
Some time reading this thread might help.
https://www.smokstak.com/forum/showthread.php?t=98323
Old 03-01-2019, 11:22:16 PM
Thanks I really appreciate the help, this will give me a place to start. There is a test I found for the regulator I will try. If itís bad I wonít be using it anymore the regulator cost 4 times what paid for the whole thing.
Old 03-01-2019, 11:27:11 PM
ulgydog56's Avatar
mite be the dynamo itself. not producing power, happened to me once...
Old 03-03-2019, 09:06:54 AM
G Sams G Sams is offline
When I replaced the regulator on my 5mm65 30 years ago, I squealed like a stuck hog at $75.
Old 03-03-2019, 10:21:03 AM
I’d buy two for that now.
Kohler Kohler K 161 T (1978) on Troy Built Tiller weak spark youngbill1946 Magnetos, Ignition Coils and Spark Plugs 3 06-10-2015 09:38:11 AM
TroyBilt 7 kw generator AVR Replacement Question colorcat Welding Shop 4 11-15-2014 09:03:39 PM
Troybilt Generator only makes 5VAC Shiner6point7 Generac Generators (SEARS, etc.) 6 01-13-2014 12:07:52 PM
Troybilt Roto Tiller ronny p 148 Farm + Industrial Antiques and Collectibles 17 05-18-2013 08:20:19 AM
Kohler 22 on a Troybilt rzt mower smokes harveje Small Air Cooled Gasoline Engines 7 04-08-2009 09:50:39 PM
