Kohler Generators
Kohler L600 throttle linkage swivel bolt question
this thread has 2 replies and has been viewed 237 times
Old 03-03-2019, 12:54:36 AM
Kenny Crenshaw Kenny Crenshaw is offline
Default Kohler L600 throttle linkage swivel bolt question
I finally got my 1967 Kohler 6.5 KW generator running. After spending a small fortune in parts, and many hours going through everything except pistons, rods, and crank, I put gas to the fuel pump and she fired right up.
I have a question. I do not remember exactly what the linkage screwed into the little brass throttle lever looked like, but something seems odd about the little threaded part that screws into the brass thingy. The threads stop short of the end to where I had to put some washers on it to take up the slack where there are no threads. The parts diagram shows the same threaded part at both ends, but mine are different.
Can one of you guy go have a look at your machine and tell me if it is the same or different? Pictures are below. Thanks!
ID:	329766   Click image for larger version
ID:	329767   Click image for larger version
Old 03-04-2019, 01:46:15 AM
Vanman Vanman is offline
Default Re: Kohler L600 throttle linkage swivel bolt question
Mine is all taken apart, but I put them together to see. There is a fingernail's gap in there. I'll stick a flat washer in when it goes back together.
Mine is almost threaded all the way up though, further than yours. Perhaps your linkage rod is turned around? The end that goes through the governor arm wouldn't need threads all the way to the shoulder.
Keith
Old 03-06-2019, 12:08:08 AM
Something tells me the threads are different, but I will pull it apart and check.
12.5JC Throttle Linkage Adjustment Question Motorhead Onan Generators 6 10-16-2018 03:19:15 AM
Throttle linkage Geochurchi Small Air Cooled Gasoline Engines 3 03-20-2016 06:24:52 PM
Hercules XK throttle linkage DustyEngine Antique Gas Engine Discussion 7 09-29-2014 05:25:11 PM
IHC 3hp M throttle linkage Meco3hp Antique Gas Engine Discussion 5 05-06-2013 08:14:57 AM
Briggs 130292 throttle linkage question W_F_Brown Small Air Cooled Gasoline Engines 4 06-02-2005 07:53:29 PM
