Scale Model Engineering Steam, gas and hot air model engines, tractors and accessories. Machining and milling castings.
Maudslay Marine oscillating steam engine
this thread has 0 replies and has been viewed 216 times
Old 03-04-2019, 01:52:13 PM
gbritnell gbritnell is offline
Default Maudslay Marine oscillating steam engine
Gentlemen,
A long time contributor on one of the modeling forums, Chuck Fellows, designed and created a model of a Maudslay Marine steam engine. It's unique in the valving that it uses to control the intake and exhaust. The rotary valve is in a separate chamber and as the cylinder rocks from side to side the valve is held stationary through a pair of links thus opening and closing the ports.
The entire build has a Victorian elegance to it with the trellis type upright supports.
Another fellow took it upon himself to do all the drawings and they were freely posted on the formum.
Not wanting to follow the mainstream I took the drawings and scaled them down by .70. This created an engine with a bore of .393 and a stroke of 1.050. The smallest screws are 0-80. It's built mainly from brass with mild and stainless steel used for the crankshaft, piston shaft and small hardware.
It also has a valve that allows the engine to run it both directions.
gbritnell
https://youtu.be/3FKiJnQyzn4
ID:	329923   Click image for larger version
ID:	329924   Click image for larger version
ID:	329925   Click image for larger version
The Following 11 Users Say Thank You to gbritnell For This Post:
Oscillating Cylinder Small Steam Engine Toesmack Steam Stationary Engines, Traction Engines, Steam Boats 5 10-17-2017 03:19:41 PM
Maxwell Hemmens oscillating marine steam engine 110V8 Antique Marine Engines and Outboard Motors 1 07-20-2010 10:55:27 PM
Oscillating gas engine JKWidener Scale Model Engineering 4 04-18-2010 08:21:16 PM
Cretors oscillating steam engine BobSaunders Vintage Toy Steam Engines and Motors 2 10-06-2008 03:24:18 PM
marine steam engine Mary Ellen Lee Steam Stationary Engines, Traction Engines, Steam Boats 3 06-08-2003 03:29:24 PM
