Kohler Generators
Need Kohler 245445 (Delco 816-24V) replacement
this thread has 2 replies and has been viewed 133 times
Old 03-25-2019, 05:23:25 PM
Kenny Crenshaw Kenny Crenshaw is offline
Default Need Kohler 245445 (Delco 816-24V) replacement
I am in need of a replacement relay for my 6.5 KW L600 Kohler generator. My relay is mounted upside down (from the factory) and got moisture in it and is now ruined. It looks like a very simple 24 volt relay that should not be hard to source in a modern version. There is a used on one on Ebay right now, but i would rather not take a chance on it if there is a modern replacement. We use 12 volt relays all of the time here at work, I would assume that there is a 24 volt equivalent. Thanks.
Name:	Delco 816-24v.jpg
Old 03-25-2019, 07:34:04 PM
Power Power is offline
Default Re: Need Kohler 245445 (Delco 816-24V) replacement
First place I would look would be truck supplies. Many trucks run 24 volt sysstems.
Second place military surplus/ supplies. All mil equipment has been 24 volt for many years.
Old 03-25-2019, 08:16:02 PM
Zephyr7 Zephyr7 is online now
+1 for looking at truck part places. You should be able to find a cube relay with a 24v coil no problem.
A lot of the military stuff will be labeled for 28v but will work fine in a 24v system is almost all cases. I doubt very much you’d have any problem with a relay.
Bill
Kohler 7.5 CMK 21 Rectifier Replacement majoday Kohler Generators 13 02-11-2018 11:12:06 PM
Kohler 10 roy replacement wap Kohler Generators 10 07-15-2017 02:32:48 AM
Kohler 40ROZ-281 Part Replacement sportmodel Kohler Generators 10 03-15-2017 09:28:56 PM
kohler relay #245445 NEED ONE ? gary born Kohler Generators 3 03-28-2015 11:11:56 AM
Replacement for a Kohler K321s engine Paul Spence Small Air Cooled Gasoline Engines 17 05-12-2010 11:23:56 PM
