Kohler Generators
Kohler 100KW Generator with White D48900 Diesel
this thread has 3 replies and has been viewed 235 times
Old 03-27-2019, 01:30:18 PM
homer1917 homer1917 is offline
Default Kohler 100KW Generator with White D48900 Diesel
Greetings: I have a vintage Kohler generator,100KW, with a 6 cyl White diesel engine, Model D4800X126. My question has to do with changing out the 2 oil filters. Filters are mounted flange down. Looking at the filter base it appears to have a bolt to let both filters drain out before removal.
So when installing new filters, you put both on dry, that's more than 2 qts of oil not included..???
What is method to get those 2 filters filled with oil before running engine....???
Photos attached below...
Name:	White D4800 Engine Oil Filters.jpg
ID:	331506   Click image for larger version
Name:	White D4800 Leftside.jpg
Old 03-27-2019, 08:38:54 PM
Email NOT Working
Default Re: Kohler 100KW Generator with White D48900 Diesel
I change all filters dry. Oil from a bottle is filthy dirty compared to filtered oil. The engine will not be harmed running 5 seconds with no load, and the oil film will always stay in place.
I have run engines much longer than that to get something out of the road with no oil whatsoever. I heard of a guy who once ran an excavator for 15 minutes with a hole in the pan to get it onto a lowboy. Once they repaired the leak it ran a full life.
Old 03-27-2019, 08:44:58 PM
Troll's Avatar
Troll Troll is offline
Maintained a set with that engine about 10 years and my predecessor did about 15, and my successor has been about 14 now. That engine used cartridge types and still does. Installed dry won't hurt it a bit.
Old 03-28-2019, 09:34:09 PM
nblack nblack is offline
Isn't it also possible that the filtration system is "bypass" instead of "full flow"? In which case, the oil pressure from the pump will go to the Journals, cranks, rockers, etc. FIRST, and the pressure diverted from the pump goes through the gallery to the filters, to be returned to the pan.
Detroit Diesel 100KW 6910a Advice GreasyIron Military MEP and Aircraft Gen-Sets 8 06-14-2016 11:07:02 PM
Fermont 100KW Cummins Generator Z. A. Bender Military MEP and Aircraft Gen-Sets 32 12-27-2015 02:32:41 PM
Empire Generator White diesel winter heating dwdw Generators & Electric Motors General Discussion 10 05-28-2013 11:29:16 PM
Kohler 3.5 EFOZ Diesel Gen White smoke coming from Stator/Rotor area Forever Kohler Generators 7 12-18-2012 12:42:08 AM
Need help with Kohler generator Model 30R0781 White Diesel Steve T. Kohler Generators 4 06-25-2008 07:14:02 PM
