Scale Model Engineering Steam, gas and hot air model engines, tractors and accessories. Machining and milling castings.
compound oil use when exhaust condensate back to boiler
this thread has 5 replies and has been viewed 309 times
Old 04-09-2019, 07:23:48 PM
adamlund adamlund is offline
Default compound oil use when exhaust condensate back to boiler
should compound cylinder oil be used in a model steam plant if the exhaust condensate is being returned to the boiler?
Old 04-09-2019, 10:33:24 PM
chrsbrbnk chrsbrbnk is offline
Default Re: compound oil use when exhaust condensate back to boiler
there is usually some sort of oil separator scheme for the return condensate the oil in boiler feed water will cause foaming
Old 04-10-2019, 06:37:33 PM
Thank you Chrsbrbnk, so provided there is oil separation in the system compound cylinder oil is the correct lubricant
Old 04-11-2019, 11:27:50 AM
John C. Neagley John C. Neagley is offline
Be sure to use the minimum but proper amount of cyl. oil needed when condensing. A close friend and Liberty Ship Chief Engineer told me they would cross the ocean on less than 5 gallons of cyl. oil used in it's triple expansion condensing engine. The failure of A.D. Baker's high pressure steam tractor was the operators using too much unnecessary steam oil. It caked up in the boiler and caused tubes to fail. Bill Van Norman,near Holland Ohio, bought a new one, used it properly, and loved it. He used it for thrashing and saw milling. Never had a problem with it. Wouldn't give it up until A.D. Baker himself came to his farm and made him an offer he couldn't refuse. Bob Rosebrock currently has the factory rebuilt 21 Baker Bill got included within in the trade.
The Following User Says Thank You to John C. Neagley For This Post:
Old 04-11-2019, 04:30:50 PM
Friedrich W. Busch Friedrich W. Busch is offline
In a condensing plant with return of condensate to boiler you should only use pure mineral oil with the highest possible demulsifying qualities. The principle of oil separators is the distinction between oil and waterous phase. Some modern compressor oils will work. Compound oils will possibly have better lubricating qualities but separation from water may be impossible. The steam launch fraternity has been suffering from this problem for ages.
The Following 2 Users Say Thank You to Friedrich W. Busch For This Post:
Old 04-11-2019, 07:59:50 PM
Thank you
Onan and Excessive Exhaust Back Pressure Handyhiker1 Onan Generators 160 10-03-2018 10:01:08 PM
Fact or Fiction: 75 hp Case tandem compound with heavy buttstrap boiler. Beth V Steam Stationary Engines, Traction Engines, Steam Boats 34 02-02-2014 07:14:48 PM
Back Shop on a boiler John Deck Steam Stationary Engines, Traction Engines, Steam Boats 15 04-05-2008 06:51:24 PM
Powerhouse condensate 1/4case Steam Stationary Engines, Traction Engines, Steam Boats 9 02-25-2007 10:00:34 PM
Boiler compound? Ron Antique Engine Archives 1 06-26-2000 12:29:00 PM
