Kohler Generators
Kohler 4.5CKM21-rv controller wiring
this thread has 2 replies and has been viewed 107 times
Old 04-28-2019, 08:43:26 PM
RMcKay RMcKay is offline
Default Kohler 4.5CKM21-rv controller wiring
Hi guys, new guy here with a bit of a conundrum. I've found the service manual online, but it doesn't have my particular version in it. Mine has a 228554 controller and all I can find show a 239396 circuit board. I've found a new 228554 on E-Bay for $499.99 but I'm not even sure that I need one. Does anyone out there have any kind of schematic or diagram for this thing that they would be willing to share? the serial # is 096641 and it's a spec 10111A. Thanks in advance, or3randy@gmail.com
Old 04-29-2019, 08:37:45 AM
Kevin K Kevin K is offline
Default Re: Kohler 4.5CKM21-rv controller wiring
The TP-5060 parts manual references your model and spec number, but it comes up with a part number of 241752 for the controller. I looked at the Ebay listing for the 228554 controller and they are asking $500 for three relays, a switch, and a couple of plugs? Wow, and I thought Onan was greedy.
Check the page I attached and see if the illustration looks like the controller you have.
Old 04-30-2019, 05:51:21 PM
LWB250 LWB250 is offline
The 239396 is a later circuit board used in the RV controller. The one you see on eBay is a conversion for the original solid state controller that was also used on these machines in the early models. Do note that the seller on eBay is a third party, NOT Kohler. However, that's not to say that Kohler wouldn't be charging an arm and a leg for it, too....
Either will work. Given the choice, I would opt for the three relay controller one, as it would be easier to troubleshoot and maintain.
But - the important question is "Why do you think you need a new controller?"
What's wrong with the unit?
Dan
Kohler controller A-246602 & diagram, wiring 246601 sjscott Kohler Generators 1 02-14-2017 01:18:07 PM
Kohler 4.5CKM21 wiring schematic dcdunn503 Kohler Generators 0 03-29-2016 12:10:15 PM
Kohler 2RH21 Controller # A-243820 Looking for schematic/wiring diagram decoy64 Kohler Generators 4 08-02-2014 06:47:46 AM
kohler Controller # c-248670 wiring diagram??? tims56ford Kohler Generators 1 04-14-2013 04:12:44 PM
Kohler 4.5CKM21-rv brushes wiring question adamstarr Kohler Generators 1 06-08-2010 04:50:55 PM
