Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles > Antique Washing Machines
Antique Washing Machines Old collectible washing machines as used on the farm.
Washing Machine Engines?
this thread has 6 replies and has been viewed 593 times
Old 09-17-2017, 09:16:38 PM
shiftlessguy shiftlessguy is offline
Default Washing Machine Engines?
What other engines other than Maytag,Briggs,easy,utilimotor were used on washers
Old 09-17-2017, 10:06:04 PM
James Bosma's Avatar
James Bosma James Bosma is offline
Default Re: washing machine engines ?
Johnson Iron Horse, after the utilimotor
I have a Nelson Brothers, kick start with dual over head rockers, I believe is off a washer but I'm not sure
---------- Post added at 10:06:04 PM ---------- Previous post was at 09:58:36 PM ----------
How about a Beatty water motor
Old 09-18-2017, 10:36:35 AM
Lauson made a small washer engine as did Nelson Bros. .
Old 09-18-2017, 12:09:03 PM
Doug Oldenburg's Avatar
Doug Oldenburg Doug Oldenburg is offline
Associated Pony, Clinton, Hummer.
"So Much Iron & So Little Money"
Old 09-18-2017, 05:13:30 PM
Default Re: Washing Machine Engines?
What model numbers on Clinton,Lauson,bummer.
---------- Post added at 04:13:30 PM ---------- Previous post was at 04:10:03 PM ----------
[QUOTE=shiftlessguy;1420471]What model numbers on Clinton,Lauson,hummer.]
I maybe lost but makin good time
Old 09-19-2017, 09:04:15 AM
Dan Baalman Dan Baalman is offline
Easy washing machine engine. Neat little hit and miss four stroke engines
Old 09-19-2017, 10:43:38 AM
John Newman, Jr.'s Avatar
Shiftless:
Hummer only made one model (E-2) and only for one or two years. They were sold by Montgomery Ward.
PTO was at the flywheel end. External mag on the back end of the crankshaft. Kick starter that spun the cam shaft.
I have a couple of these. One has a brass ID tag and the other is aluminum.
Briggs Washing Machine Engines Dengine Small Air Cooled Gasoline Engines 0 03-30-2014 10:32:46 AM
Model 72 washing machine turbo Maytag Engine Collectibles 6 02-10-2014 02:00:19 PM
Anybody ever seen a B&S WM on a washing machine? Meco3hp Antique Washing Machines 17 12-11-2013 01:25:02 PM
Washing machine. Sammy Antique Washing Machines 4 04-22-2013 10:14:28 AM
Washing Machine? Andrew Albrecht Antique Washing Machines 10 01-14-2006 07:25:06 PM
