Monarch 10EE on eBay
this thread has 5 replies and has been viewed 597 times
Old 08-12-2018, 05:52:53 PM
930dreamer 930dreamer is offline
Default Monarch 10EE on eBay
Would this be a long shot project?
https://www.ebay.com/itm/Monarch-Mod...0/142896136293
Old 08-12-2018, 11:36:48 PM
Jim McIntyre's Avatar
Default Re: Monarch 10EE on eBay
There's no way to tell really. I'd be leery of a eBay seller with 98.3% feedback. But, if you can afford the gamble, the 10EE is a great machine...
Old 08-13-2018, 10:02:47 AM
Motor drives on those can be pretty complicated. That one is likely to have three giant vacuum tubes as part of the motor control - yes, you heard me right - vacuum tubes. And the actual motor current goes through them. And there is a HUGE rats nest of control wiring that goes along with them. The earlier Ward Leonard motor generator drives were less complicated but still not simple. One common fix is to replace the original motor and drive with a VFD.
A bigger issue is the condition of the lathe itself. Some are pristine and others are well worn. You cannot tell unless you examine the machine. A pristine 10EE is a joy to work with but a worn out one is just another clapped-out lathe.
Old 08-13-2018, 12:45:39 PM
It would probably be best if you could convert it to a VFD. These are precision lathes but the through hole is small compared to modern lathes, it's a big foot print for the work size. If you need the precision it can't be beat, for all around hobby work you may be happier with something else.
Old 08-13-2018, 01:41:35 PM
Sold for $2025, I was the first bid and was outbid in the last few seconds, no biggie.
Old 08-13-2018, 06:12:13 PM
tdmidget tdmidget is offline
You might even be lucky. Anyone who piles chucks and faceplates on the ways of a 10EE is not likely the kind who took care of it.
PS; you ARE lucky. A closer look reveals that everything bare has been wirewheeled or scotchbrited severely. Everything in the pic is on pallets. Fly by night dealer.
Does anyone need a Monarch 10ee bed? 930dreamer Machine Shop and Tool Talk 3 02-25-2013 07:28:26 PM
Monarch 10ee lathe 930dreamer Machine Shop and Tool Talk 11 12-10-2012 09:04:31 PM
Monarch 10EE lathe parts wanted Trevor Dafter Smokstak Down Under 0 10-28-2009 05:30:34 AM
Move EBAY stuff to EBAY forum? Peter eBayŠ Auction Discussion 11 07-26-2007 08:45:16 PM
