3hp Lister No.CS25358 Spec. 28/10
this thread has 39 replies and has been viewed 1116 times
Old 07-23-2019, 03:42:35 PM
AngrySailor AngrySailor is online now
Default 3hp Lister No.CS25358 Spec. 28/10
HARRY!!! I can’t post photos.
I picked up this engine yesterday. It came with a Lister 32/43V 40a DC generator also.
The engine has a small piece chipped out of the flywheel (I have the missing piece) but otherwise seems undamaged. There was oil in the water jacket when I removed the cooling lines though. I’m going to drain the crankcase next and see if there’s an ny water. It turns over free and has compression. I haven’t turned her much as I don’t want to pump any water around if there’s any present. The rack is stiff and the pump plunger stays up after injection. The fuel system will have to be gone through. If she’s not cracked I’d say she’s an easy runner.
Edit: spec no.208/10
Old 07-23-2019, 04:28:52 PM
John Newman Jr.'s Avatar
John Newman Jr. John Newman Jr. is offline
Default Re: 3hp Lister No.CS25358 Spec. 28/10
I’ve been getting error messages when I try to upload pictures too but with repeated attempts I am eventually successful.
Last batch took about 6 tries.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 07-23-2019, 04:41:43 PM
Managed to move it under my lifting beam and get her high enough to drain the sump. No water, lots of sludge.
Old 07-24-2019, 01:30:52 AM
Cleaned the crankcase sump. Lots of sludge in the lower sump but the screen wasn’t plugged. Crankcase inspection gets a pass for refill and start attempt.
Fuel pump freeing up with penetrant and working by hand. I will make sure this is good before any attempt to start though. I should build me an injector tester...
---------- Post added at 11:58:38 PM ---------- Previous post was at 11:50:22 PM ----------
Con rod dipper seems “non factory” but I honestly have no idea... muh first Lister
---------- Post added 07-24-2019 at 12:30:52 AM ---------- Previous post was 07-23-2019 at 11:58:38 PM ----------
Con rod dipper definitely not factory.
HIGH NOTE: SHE RUNS!!!
Just kept working the the fuel pump and she came free, water bottle of fresh diesel gravity feed to the injection pump and she lit right off!
Old 07-24-2019, 04:58:26 AM
https://youtu.be/jG8B_HxobJc
Didn’t catch the first start but imagine I cranked it...
The Following 2 Users Say Thank You to AngrySailor For This Post:
Old 07-24-2019, 12:02:10 PM
These Lister engines have such a sweet sound to them. I could listen to this engine all day and not get annoyed.
Robert
Old 07-24-2019, 01:38:39 PM
She was sweet sounding even without a muffler!
Harry, still can’t uoload pics to this thread. Worked in the other threads though
Lister 3 hp + lister dynamo 19fingers55 Smokstak Down Under 17 01-01-2015 03:18:52 AM
Lister A spec no confusion E27N Smokstak Down Under 2 07-09-2013 06:35:43 AM
Lister 4kw onan adapted to Lister Iwasthere61 Onan Generators 3 01-31-2013 11:36:54 PM
Lister 12/2 30kw koler generator head COOLING The Lister????? mytickets Vintage Diesel and Oil Stationary Engines 2 04-12-2010 04:34:18 PM
