Smokstak Down Under
Lister 3 hp + lister dynamo
this thread has 17 replies and has been viewed 4672 times
Old 03-09-2013, 06:23:33 AM
19fingers55 19fingers55 is offline
Default Lister 3 hp + lister dynamo
Found this engine and would like any information I can find
please.. I have put photo's up for help with information.
thank you
Ian Bonnor
Old 03-09-2013, 11:44:38 AM
Ironsides Ironsides is offline
Default Re: Lister 3 hp + lister dynamo
Ian,good find unusual voltage range,may have been some specialist equipment.If the dynamo has 4 brushes it will probably be a starter generator,(2 to start 2 to charge).The ones like this I have seen normally were 32 volt,be very careful if you get this one running and charging as that voltage and amps would ruin your day if it bit you,keep cranking,Norm
The Following 2 Users Say Thank You to Ironsides For This Post:
Old 03-18-2013, 04:45:47 AM
jayvee jayvee is offline
Hi Ian,
You probably already know this;
Your engine was built around 1928.
The Spec A56 indicates twin flywheel, tank cooled and no suction carburettor. The "E"= Electric (lighting plant/generating set)
The Flywheels should be 22 1/2inches x 2 3/4 inches.
The sub base should accomodate the fuel tank.
A344 or A345 should be cast into the base "somewhere".
Sub bases with internal fuel tanks were generally supplied with engines exported to Aust & N.Z. for use with sheep shearing equipment.
From Spec 12 batches of A & B types were being built for 'Austalian type' engines.
Batches of several hundred 'Australian type' engines were supplied to this and later specs, but due to a lack of information it is impossible to determine many differences between these and the standard production engine.
The sub base depth was increased in order to accommodate the larger 'E' flywheels.
Is the 'box' sitting on the dynamo, the switchboard?
What are the numbers on the i.d. plate (bottom photo)?
Would it be possible to take photos of the "other side" and dynamo
Hope this is of benefit.
Best wishes, jayvee
Old 03-18-2013, 06:28:51 PM
Thanks very much for the info..I am picking this engine up in a couple of weeks and I will get the rest of the info then..I dont believe it has a switchboard so i would be very interested in any details available
cheers
Ian
Old 03-19-2013, 04:16:51 AM
Lanzb Lanzb is offline
Name:	lister junior gen set 008.jpg
ID:	160772 Would the switch board look like this one?
The Following User Says Thank You to Lanzb For This Post:
Old 03-19-2013, 07:16:38 PM
Hi Lanz & Ian
I am unsure of what switchboard looks like, but on closer examination of the first/top picture, the box sitting on top of the dynamo is in fact a radiator which is belt driven from between the flywheel & dynamo. A hose can be seen coming to/from the engine head to the radiator top.
The switchbox (to the right of radiator) is missing. Its mounting posts with chrome dome nuts can be seen.
It will be interesting to see other pictures of unit.
Best wishes, jayvee
Old 03-20-2013, 03:00:26 AM
Those chrome nuts are actually just for a cover for the terminal block. The switch board would have been on the wall or mounted on two posts screwed into the base. I will take a pic of my one over the weekend for you showing how it mounts.
Old 03-20-2013, 04:08:32 AM
Hi Lanz,
No dramas. Switchbox/Terminal block, could be one & the same. I have not seen these units for a long time and I'm unable to find my pictures of same.
Look forward to seeing your pictures.
Best wishes, jayvee
Old 03-23-2013, 06:26:56 AM
So here is some pics of my unit, It's a lot earlier than your one but I bet everything would still mount the same.Click image for larger version
The Following 2 Users Say Thank You to Lanzb For This Post:
Old 03-23-2013, 08:01:21 AM
Hi Lanzb,
Thanks for the pics.
Is your engine/unit around the 1924 era?
I am more aware of Ian's style than yours. Certainly has my attention.
Looks like more reading & research.
Best wishes, jayvee
Old 03-23-2013, 06:31:34 PM
From memory 1925.
Old 04-20-2013, 02:26:06 AM
Hi Jayvee'
Any info you can dig up would be appreciated as I have trolled the world looking for some info and can not find one the same
cheers
Ian
Old 12-24-2014, 04:59:49 AM
mygoggie mygoggie is offline
Hi,
I have determined that I have the same dynamo as the one you have pictured here. Please look here - http://www.smokstak.com/forum/showpo...60&postcount=6
If you can give me more info on this dynamo/generator I will really appreciate it.
Thanks!
Old 12-24-2014, 05:07:06 AM
What info do you need?
Old 12-24-2014, 12:29:46 PM
Basically anything that you might have on this. A quick of the top of my head:
Terminal connections for charging and starting.
What regulators are required and how to connect them.
What size (kW) Lister engine is required.
Thanks!
Old 12-31-2014, 07:23:02 PM
The red wire is Pos out, the black wire is Neg out, and the green wire is the Pos field back in. There is a rheostat between the red and green wire to adjust the field voltage.
ID:	214696   Click image for larger version
ID:	214697   Click image for larger version
Old 12-31-2014, 09:59:12 PM
Eric Schulz's Avatar
Eric Schulz Eric Schulz is offline
Here's what it looked like when new. A 1927 advertisement.
Eric
The Following 3 Users Say Thank You to Eric Schulz For This Post:
Old 01-01-2015, 03:18:52 AM
Thank you guys for your trouble. It is really appreciated.
Lister 4kw onan adapted to Lister Iwasthere61 Onan Generators 3 01-31-2013 11:36:54 PM
My New Lister J robert hamilton Smokstak Down Under 10 06-21-2012 08:01:07 AM
lister jp3 newway1978 Vintage Diesel and Oil Stationary Engines 1 06-06-2012 09:55:31 PM
Lister 12/2 30kw koler generator head COOLING The Lister????? mytickets Vintage Diesel and Oil Stationary Engines 2 04-12-2010 04:34:18 PM
Lister HR2 John H Donnelly Vintage Diesel and Oil Stationary Engines 4 11-19-2009 05:24:32 PM
