Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Diesel and Oil Stationary Engines
Vintage Diesel and Oil Stationary Engines Fairbanks Morse, Lister, Petter, Witte and other pump injected Diesel oil engines.
Lister 12/2 30kw koler generator head COOLING The Lister?????
this thread has 2 replies and has been viewed 5413 times
Old 02-12-2010, 12:07:41 PM
mytickets mytickets is offline
Default Lister 12/2 30kw koler generator head COOLING The Lister?????
I have a old lister it has about 3 hrs total run time so no build up of rust in the cooling ducts.I run my car on WVO and my truck.Would like to try to use the WVO as a cooler for the lister and as the oil gets hot 180* or so, would then run the oil thru a dieselcraft centrifuge to clean it for fule use .may then use hot oil to run the lister I have the set up on a cart so it is moveable.I need some ideas on how the set up would look .Anybody doing this??
Thanks Jeff
Old 02-12-2010, 04:16:59 PM
Contaucreek's Avatar
Contaucreek Contaucreek is offline
Default Re: Lister 12/2 30kw koler generator head COOLING The Lister?????
Hmmm diabolical thinking, I like it. Can't wait to see the input on this. My initial thought is great idea but how do you cool the oil ? with a radiator ? I had thought about a "tank within a tank" for my tank cooled 16/2 that would allow the oil to be preheated by the water. just tossing around ideas here, remember if you have an open cooling system the oil wont lose any heat by evaporation
Old 04-12-2010, 04:34:18 PM
rec409 rec409 is offline
anymore thoughts on this idea I like it.....
cooling of lister diesel clone rhud Vintage Diesel and Oil Stationary Engines 9 06-03-2011 01:14:20 PM
Generator Head for Lister SL2 Slowturn Vintage Diesel and Oil Stationary Engines 5 04-13-2009 09:40:59 PM
Lister generator B. K. Lahey Vintage Diesel and Oil Stationary Engines 0 10-11-2008 05:17:45 AM
Hawk-Lister Gen Set (Gen Head Question) Davesr Vintage Diesel and Oil Stationary Engines 6 09-08-2008 01:45:19 PM
Generator head for 4.25 hp Lister Adair Orr Vintage Diesel and Oil Stationary Engines 4 10-04-2007 05:37:49 PM
