Onan DJC wiring id
this thread has 3 replies and has been viewed 2322 times
Old 10-07-2008, 12:00:16 PM
Jdnutinwa Jdnutinwa is offline
Default Onan DJC wiring id
I have an Onan 12.0 DJC diesel generator. I am told that it came out of a rig manufactured in Canada. There is no ID plate on the unit, just a decal that has all but the DJC part smeared off..
I am wiring it as a backup generator, and I am wondering if anyone can help me figure out what line is what. I have a pretty good idea, but the electrician want to know for sure.. It is a single phase 120/240 unit. I have to legs that are hot, another leg tied to the ground, and of course a ground.. If I am remembering right, the neutral bonding needs to be un-done before wiring to the panel. The lines in the generator have markings on them like L4, (sorry I don't have the actual markings handy) Does someone have a wiring schematic that lists what identifiers go to what line?
Chris
Old 10-07-2008, 03:58:48 PM
JamesB JamesB is offline
Default Re: Onan DJC wiring id
I think this might be what you are looking for.
Hope it helps.
James
Redford, Michigan
Pages from Onan_YD_2-7.pdf
The Following User Says Thank You to JamesB For This Post:
Old 10-07-2008, 10:03:32 PM
James,
That looks like what I need. Just to check myself, as I read it, T1 and T4 are hot legs and T2 and T3 would be ground and neutral?
Chris
Old 10-07-2008, 11:32:43 PM
T2 and T3 get attached together as the neutral for 120/240. If you also attach them to ground then it is bonded which you may or may not want to do depending on your specific hook up situation.
James
Redford, Michigan
Onan 4.0 CCK wiring diagram 37 racin Onan Generators 8 07-16-2008 09:47:57 PM
Onan CCK wiring sam c Onan Generators 2 06-23-2008 01:33:06 PM
needs some help with onan 3mdsp wiring mikeinnh Onan Generators 11 01-16-2007 09:05:26 PM
Wiring Onan CCK J Gambrell Onan Generators 2 01-28-2006 12:12:31 PM
help on Onan 2-cyl wiring ken phillips Onan Generators 0 10-25-2003 03:06:54 PM
