Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Garden Tractors / Mowers / Scooters
Garden Tractors / Mowers / Scooters Vintage lawn and garden tractors, mowers, snowmobiles and other old machinery that is driven by small air cooled engines.
Just acquired Goodall mower with Lausen motor
this thread has 15 replies and has been viewed 2828 times
Old 06-08-2009, 02:39:10 AM
Eightreindeer Eightreindeer is offline
Default Just acquired Goodall mower with Lausen motor
found serial # 18L16820 on deck. Do not find any on motor Have pic of it & will try to attach want to know approx date of mfg. & all other info to restore. Motor turns over & has good compression. has lausen motor some ppl tell me 4 cycle. & maybe have a one lobe cam which opens both valves will try to get it to fire up this week
Name:	Goodall mower 001.jpg
ID:	56084   Click image for larger version
Name:	Goodall mower 002.jpg
Old 06-08-2009, 06:32:35 AM
Leonard Keifer Leonard Keifer is offline
Default Re: just aquired Goodall mower with lausen motor
Looks like a really nice mower. That shield on the front is usually missing and the decks tend to crack easily.
Old 06-08-2009, 07:25:32 AM
K D Redd K D Redd is offline
I have one just like it. A little rougher maybe. I need a float for the carb. as mine has had water in it which crushed the float in freezing weather. Yes, the engine uses a single lobe cam.
Kent
Old 06-08-2009, 07:35:57 PM
Default Re: Just acquired Goodall mower with Lausen motor
ok.....got mine to fire up tonite....used a lil pumpspray bottle with gas in it....tank & carb have varnished gas in them...need to clean good.... but did have it runnin for bout 3 min with squirtin a lil at a time to keep runnin...sounds like a lil screamer too.....muffler is burned out tho...gonna pull tank & carb & clean...
Old 06-08-2009, 07:45:08 PM
ok.....would like to try & find out date of mfg....also wat did they sell for then.....gonna go talk to the pp I know who did own this one too....it was in their lil shed out back with 2 inches of dust on it btw....wat lausen engine is on this one??I would like to find out anything I can on this one....it's a lil younger than me I think maybe 2-4 yrs.....lol I can remember lookin at one when I was a real lil kid.....4-5 yrs old I think... neighbor had one in Schleswig Iowa we moved from there in '55'but he had his bout '50-51"
Old 06-08-2009, 09:15:21 PM
Scott Wenrich Scott Wenrich is offline
Images: 139
Judging by the carby(tillotson mt-series) it probably is an RSH of some type.The one i have is a lauson rsh-775 wt and it came off a goodall mower.Yes it is a 4 stoke engine so if you run it,make sure she has oil in the sump.The plug is on the opposite side of your pictures.If i remember right it's a 2 and 1/2 hp engine.What do the two tags say? One should be for the mower itself and the other for the engine.My rsh was made in '56 so yours could be in that same time frame give or take a couple of years.
Craig DeShong could give ya a heck of a lot more info if he so desires to jump in here.
Scott
Old 06-08-2009, 09:36:28 PM
Craig DeShong's Avatar
Craig DeShong Craig DeShong is offline
Images: 143
I think Scott has nailed it. Looks like a RSH-775. This is the RSH version of the Lauson engine that Lauson made under contract for Goodall so you will only see this Lauson engine on a Goodall mower. Lauson made a RSV that looks a lot like this engine but it was the Lauson version, free from the Goodall contract, and Lauson sold the RSV to many different mower manufactures. There is what I feel is an excellent thread on this engine that K D Reed started that you can find here http://www.smokstak.com/forum/showthread.php?t=22678 .
K D Reed, just about any Tillotson MT carb. should have a float that will work. They seem to be pretty much interchangeable.
My Photos
Lauson Small Engines
Old 06-08-2009, 10:52:10 PM
ok...took a few more pics.... 1st is tag on right side (when standin at handles) 2nd is tag on left side 3rd shows wat would have been bottom on horitz engine.....no tag there... 4th is flywheel cover .... & 5th (in next reply) is the clearview breather....notice the crack.... where can I find a replacement..? the serial # I get off left tag is ... 18L16820
Name:	Goodall mower 003.jpg
ID:	56182   Click image for larger version
Name:	Goodall mower 004.jpg
ID:	56183   Click image for larger version
Name:	Goodall mower 005.jpg
ID:	56184   Click image for larger version
Name:	Goodall mower 006.jpg
Old 06-08-2009, 10:57:23 PM
can I get a replacement for this anywhere.??
Name:	Goodall mower 007.jpg
Old 06-12-2009, 07:23:22 PM
have noticed that the pics I have seen of the Goodall mowers on here all have a steel rimmed solid wheel main tire.....while mine has a ballon type tire in it...(prolly a tube type)....so wat was on them.....?? does anybody have a clearview oilbath air cleaner part that I can buy..?? mine has a big crack....... can that b repaired..?? c the pic above...
Goodall Push Mower K D Redd Garden Tractors / Mowers / Scooters 29 07-19-2014 06:01:09 PM
Goodall Mower wheelhorseman Garden Tractors / Mowers / Scooters 4 08-07-2009 03:23:37 AM
Goodall Vista Mower Goodall Mower Garden Tractors / Mowers / Scooters 1 07-07-2008 07:40:12 PM
Goodall Mower / Lauson Engine LCJudge Antique Gas Engine Discussion 0 01-02-2008 11:56:22 AM
lausen gears larry harding Antique Engine Archives 2 09-10-2002 07:37:55 AM
