Welding Shop
Lincoln SA200 That does not weld.
this thread has 11 replies and has been viewed 10825 times
Old 11-12-2012, 08:09:38 PM
dadam2308 dadam2308 is offline
Default Lincoln SA200 That does not weld.
A newbie needs some advice.
I purchased a Lincoln SA200 for $250.00. To date I have rebuilt the mag and carb, new plugs and battery. I figure at this point I am in it for about $450.00 and the engine runs great.
I started looking at the welder part of it and not so good. I flashed the exiter and now have about 116-118 volts dc to the outlet. Still does not weld. I was advised to take the two wires off the fine amperage rheostat and jump them, still dead. At this point I am left to think its the shunt coils. I believe these go for around $500.00.
What is the best way to test these coils? There are 2 wires that go along the bottom of the large generator and through the bottom of the exiter. One is black that goes up to the + brush holder on the rh side. The other is red and is joined with a small bolt to a solid copper wire. Please be aware that my strong point is mechanical and not electrical.
If there is a way to ohm these and somebody could explain it to an electrical idiot like myself, that would be greatly appreciated.
Lastly, my other thought is to give it up. What would be a reasonable price for an SA200 that runs great but does not weld?
Code 7789
Model SA200-F163
SN A828654
Thanks.
Old 11-12-2012, 09:37:16 PM
Default Re: Lincoln SA200 That does not weld.
I'm in the same boat as you are, electrically. I've heard of the brush holders getting oxidized and not permitting the brushes to engage the armature, thus giving the condition you describe. Not saying thats your problem but be sure the brush holders are clean and all the brushes floating as should.
Old 11-13-2012, 10:42:24 AM
Jim Sherman's Avatar
Just looked up your machine, it's a 1977 hex barrel. The hex barrel machines are known to have the shunts go out. The reason is Lincoln switched to aluminum wire with a copper coating, they corrode at the terminals and viola you're done. Hybriweld has a good deal on shunt coils. I will see if I can dig up the test procedure for "ohming" them. I did mine but I could tell you how to do it without re-reading the procegure. Don't give up! Even if you have to dump another $500 into it, it's probably still worth it.
---------- Post added at 06:42 AM ---------- Previous post was at 06:37 AM ----------
http://billswelderrepair.com/SA200schematics.html
Look at the above link. You should be able to pull the ohming process off the first page.
Try these guys for your Shunt coils:
http://hybriweld.com/products/shunt-...2a9291eb46db98
I have not purchased their coils but I have heard nothing but good things about them.
If you test the shunts and everything ohms out correctly, I'd look at the idler, it's possible the solenoid on the idler is not actuating.
Jim Sherman
My website
The Following User Says Thank You to Jim Sherman For This Post:
Old 11-13-2012, 10:24:02 PM
Pat
When you say brush holders, you are referring to the larger ones that are about 1 inch wide by 3 inches long, on the larger of the two armature. I did notice that the copper armature was black from corrosion, Do you think that would prevent it from operating?
---------- Post added at 09:24 PM ---------- Previous post was at 09:20 PM ----------
Thanks for the info Jim, I will try to ohm the shunt coils. I hope thats not the problem as it looks like a major job to replace them.
Old 11-13-2012, 11:45:53 PM
It's not all that bad, but you have to get them pressed in and out. The best thing to do is find a local welder repair place, bring your barrel and new coils to them and have them press out the old and in the new.
Jim Sherman
My website
Old 11-18-2012, 11:16:27 PM
Would corrosion such as this prevent the machine from welding. I polished up the armature but it was too late to start it up. I also found 1 set of brushes that were not cooperating, freed them up. Hopefully that will make the difference. Find out tomorrow.
Cant figure out how to post the picture.
Old 11-19-2012, 12:04:12 AM
Yes it would.
Jim Sherman
My website
Old 12-09-2012, 09:21:04 PM
dkamp dkamp is offline
eMail NOT Working
So what's the result? Any success??
Old 04-11-2013, 11:22:54 PM
Call Lincoln. They are very helpful. Yes trace circuit and check continuity of everything. Compare with the schematic. A proper operating commutator gets shiny black and doesn't need polishing unless there is corrosion.
Old 04-12-2013, 04:38:59 PM
Black Eagle Black Eagle is offline
Any progress?
Old 04-12-2013, 05:11:01 PM
Kpack
Sometimes we hear back and sometimes we don't we just keep wondering
Old 04-14-2013, 12:44:33 PM
Dempster Dempster is offline
Others mentioned everything to try but a low idle set too low will not let idler work and will not strike a arc. Set idle up or try pinning it on high if has R57 idler then if no arc keep looking at connections and coils.
Lincoln SA200 running like poo dtscott Welding Shop 6 09-04-2011 12:45:13 AM
Lincoln SA200 welder generator, no output? Arkie Welding Shop 9 03-24-2011 08:43:48 PM
Lincoln SA200 Welder clintonmetalcraftsman Welding Shop 4 08-13-2010 09:25:38 AM
I cant seem to get complete information on the Lincoln Shield Arc SA200 DC we own. rocketgirlee Welding Shop 2 05-05-2010 06:05:31 PM
Seating brushes in a Lincoln SA200 mr welder Welding Shop 2 02-28-2009 10:13:09 PM
