Magneto Question
this thread has 2 replies and has been viewed 1298 times
Old 05-25-2004, 09:26:54 PM
Rich Martz
Default Magneto Question
Hello, I have a Bosch AB33 mag that is not working. Is there any tests that I can run on it it before I send it out for repair? I have already remagnetized the magnets and cleaned the points. Thanks in advance for any help..........and Thanks Harry
Old 05-25-2004, 10:41:58 PM
rudy
Default Re: Magneto Question
90% of the time on ab33 mags the coils are bad. the insulation on the wire breaks down. then what you get is a internal short which can not be found with an ohm meter. also the magnets will probally need charging. redoing the coil is best left to someone who. repairs mags, because the collector ring has to be pulled. you dont want to break this.their is also a condensor in the coil that needs to be changed. hope this helps.
Old 05-26-2004, 01:02:19 AM
Andrew Mackey
Did you remove the magnets from the case to charge them? If you did, they probably are compromised, as the magnetism on the AB 33 and 34 mags swop locations when removed. Their original magnetic configuration is thru the thin section of the magnet, and they are always charged on the case. Most of the AB33 and 34's have critical points settings, and the 34's were known for bad coils. The 33's were suseptable to bad condensers. Make sure the case is mounted on a clean metal ground - no paint under the mag-mount! Andrew
IHC M Magneto Question Tom Martin Antique Gas Engine Discussion 10 02-21-2007 09:19:16 AM
Magneto question. JBailey Antique Gas Engine Discussion 7 11-15-2005 11:48:58 PM
Magneto question Sky Antique Gas Engine Discussion 5 08-28-2005 10:28:40 PM
B & S Magneto Question B.Sparks Small Air Cooled Gasoline Engines 1 05-12-2005 11:54:12 AM
Magneto Question Tom Wahl Antique Engine Archives 2 06-05-2002 12:39:54 AM
