Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Horse Drawn Equipment
Horse Drawn Equipment Old iron designed for the purpose of hitching up to a horse or a team. This old iron machinery may be used or demonstrated while hooked to an old iron tractor too.
Massey Harris and Cockshutt binders
this thread has 5 replies and has been viewed 3774 times
Old 02-23-2011, 05:41:59 PM
Default Massey Harris and Cockshutt binders
I am looking for info on massey harris and cockshutt horse drawn and tractor pull type binders pictures,history ect... i have seen some of both makes but am not shure when the were made or all the models made eg no#16 7b ect... any help with this i like both but dont know much about eather make any massey and cockshutt guys out their know.John
Old 03-16-2011, 11:14:42 PM
Rick Schmitz Rick Schmitz is offline
Default Re: Massey harris and cockshutt binders
A little history tid bit I read up on was that Massey had purchased the Toronto Reaper company in 1881 and Harris acquired the Osborne company in 1863.Apairently there was some intense completion between the two company's in the binder market until their merger in 1891.
Massey Harris then started producing their own mowers/binders/reapers and called them "Brantford" named after the town they were manufactured in.
I believe they started putting their own name on their equipment in the beginning of the century.
Old 06-06-2011, 01:36:22 PM
GlennFarmer GlennFarmer is offline
Hi Rick, I just noticed your 2009 post while searching for info on a "Brantford" reaper - thanks! You don't happen to recall where you read the info about dating the "Brantford" versus "M-H" labelling, do you? Not, of course, that I don't believe you, but I'd love to read more.....Thanks, Glenn
The Following User Says Thank You to GlennFarmer For This Post:
Old 06-21-2011, 09:51:52 PM
Glenn
I read that info from the book "The Advertising of Massey Harris/Massey Ferguson"
I believe that book is still available.
The Following User Says Thank You to Rick Schmitz For This Post:
Old 06-26-2011, 02:39:35 PM
Default Re: Massey Harris and Cockshutt binders
Thanks Rick! Will look for it....
Old 08-23-2017, 05:43:52 AM
TomQ TomQ is offline
Good morning Casertractor;
I was wondering if you had any info on the M H #16 grain binder?I thought that this older thread might have some insight into how to change the wooden canvas slide on the left side of binder.I have one that I am refurbishing to use,but I can not figure out how the massey guys locked the drive gear onto the upper canvas drive roller? any suggestions!Tomq
The answer to the problem is the gear is threaded onto the roller stub shaft that drives the roller,standard 5/8" left hand thread. Now my cabinet maker skills will come into play to fab up a new slider!!! Tomq
Massey Harris GP 4WD Phil Johnson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 42 11-08-2012 11:58:09 AM
Massey Harris GP regm00 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 03-04-2010 09:06:36 AM
Massey Harris R20 Will in MN Antique Gas Engine Discussion 0 07-08-2007 01:23:35 PM
Massey Harris 4 H P KeithT Antique Gas Engine Discussion 1 06-02-2006 10:54:29 PM
Massy Harris binders Bill J Antique Gas Engine Discussion 0 02-08-2005 10:04:24 AM
