Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Antique Engine Photos
Antique Engine Photos OLD gas engines, hot air engines, Diesels and steam engines. An electronic photo gallery to showcase the best of your old engine collection.
London Hit & Miss Engine Project
this thread has 15 replies and has been viewed 2475 times
Old 01-03-2016, 08:07:48 PM
Miles1 Miles1 is offline
Default London Hit & Miss Engine Project
This is my first Engine project.
It is a London hit & Miss that came from my Grandfather's Farm.
not sure on the HP or the year of the engine.
this was gong to be my Dad and my project but he past away a year ago.
It is my New Years Resolution to restore the Engine.
Some of the pics of the first day I started to work on the engine are on the meet and greet thread.
Today I have disassembled and cleaned parts up, Lap the valves and start gasket making.
I have an issue with the Piston not move in the cylinder head.
One issue with that was a chipmunk had made a nest in the head.
I have spent 1/2 an hour cleaning the crap out and have a pic of the stuff.
Now I'm putting more penetrating oil in the cylinder hoping it will help.
If anyone has another way of getting the piston freed up I would appreciated it.
Here are the pics from today's work done.
Hope you enjoy.
MIles
ID:	242939   Click image for larger version
ID:	242940   Click image for larger version
ID:	242941   Click image for larger version
Old 01-04-2016, 12:07:33 AM
WesPete66 WesPete66 is offline
Default Re: London Hit & Miss Engine Project
Miles,
That will be a nice looking engine when you're done.
Have you searched the forums here on smokstak? I think you'll find posts about other London engines that are around.
Just a thought, but can you handle that piston like a Maytag cylinder? by pumping grease (pressure) against the piston?
Best of luck!
Wes
The Following User Says Thank You to WesPete66 For This Post:
Old 01-04-2016, 11:28:25 AM
jamesk815 jamesk815 is offline
Images: 17
Smile Re: London Hit & Miss Engine Project
Westpete66
Just take your time and go at it slow, it well come out. I would use the grease gun method as a last resort. A grease gun puts out a lot of pressure;
and if the piston doesn't move you can brake something else, and cause even more troubles. Just my two cents worth, based on years of playing with
these old engines.
The Following 3 Users Say Thank You to jamesk815 For This Post:
Old 01-04-2016, 07:42:35 PM
Today I got the piston moving a little then went to the grease to push it out the rest of the way. No damage and it came out smooth
the Piston has some pitting on top and the compression ring was stuck in the groove of the piston (corrosion) the other 2 rings spun free. Piston looks good but I need to replace the top compression ring for sure if not all of them.
Have all my gaskets made now but need to get 2 copper rings for the intake and exhaust valves. I will need a muffler, all I have left of the old one it the pipe. The fuel pump works well after cleaning and the carb is back together.
the only thing that worries me is the pitting in the cylinder wall. I have some pic to show of it. Not sure where to go from here on that ( Any Thoughts).
As for some of the parts like the piston rings, Valve Gaskets, and the muffler any particular place to acquire these items?
Have A good One
Miles
ID:	242979   Click image for larger version
ID:	242980   Click image for larger version
ID:	242981   Click image for larger version
The Following 3 Users Say Thank You to Miles1 For This Post:
Old 01-04-2016, 09:09:53 PM
Amax Amax is offline
Personally, I would not worry about the cylinder pitting. It might smoke a little but that's about it. You could lightly hone the cylinder but don't try to remove the pits as you will remove too much material.
The Following User Says Thank You to Amax For This Post:
Old 01-05-2016, 07:41:46 AM
Elden DuRand's Avatar
Images: 11
Miles:
I think I'd just give the rusty part a good wire brushing and honing to remove the loose rust and take off the high spots, put it back together and see how it does.
You might be surprised!
Take care - Elden
http://www.eldensengines.com
Old 01-05-2016, 09:26:03 AM
Geist Geist is offline
Miles
when I was at the Coolspring, Pa show a old man told me that pits in the cylinder will not hurt you but grooves will kill you
that makes sense, so I would put it back together, as it was said in another post you may be surprised of the outcome
let us know how it works out,
Randy
The Following User Says Thank You to Geist For This Post:
Old 01-06-2016, 08:07:54 PM
Thank you for your input it is appreciated.
I only have one issue a broken piston ring, so I'm down to 2 rings plus I still need copper washers for the valves to seat them in the head.
Just need to make an intake tube from the gas reservoir to the pump and wire her up.
So Close to the prize.
Old 01-09-2016, 04:52:51 PM
stevengine stevengine is offline
Thumbs up Re: London Hit & Miss Engine Project
Hi there:
Certainly nice to see another London engine. They are very rare here in the UK & I have one of the few that are known about.
I wrote an article for the "Stationary Engine Magazine" back in October 2013 regarding their history & showing both my engine & also my 1924 Lister A type, its certainly easy to see where Arthur Freeman-Saunders got his Idea's from
If you go to Youtube & type "London Engine At Astle Park 2015" it will show footage of mine running at last years event.
Regards:
Steve
The Following User Says Thank You to stevengine For This Post:
Old 01-09-2016, 11:43:42 PM
I got it started today and to my surprise, it started and ran better than expected. thought I would have more problems and issues. Guess I got lucky.
Here is a short Video of it running.
http://vid154.photobucket.com/albums...109_125654.mp4
london engine, new project, with pics & #,s David A. Antique Gas Engine Discussion 2 12-18-2015 12:54:07 PM
LONDON Engines built by London Gas Power & Co., Ltd. Denis Rouleau Antique Gas Engine Discussion 16 09-02-2015 04:26:18 PM
london engine, new project David A. Antique Gas Engine Discussion 1 08-17-2015 12:53:21 PM
My 2nd hit and miss, and my first real project Jeff and Maria Smith Antique Gas Engine Discussion 11 02-24-2009 02:31:05 AM
London Engine Bill Myers Antique Engine Archives 3 02-05-2003 11:02:43 AM
