Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Antique Engine Photos
Antique Engine Photos OLD gas engines, hot air engines, Diesels and steam engines. An electronic photo gallery to showcase the best of your old engine collection.
Leader Iron Works Pump
this thread has 5 replies and has been viewed 1298 times
Old 03-14-2016, 09:17:38 AM
linckeil linckeil is offline
Default Leader Iron Works Pump
Not sure if this is the right section to post this...
I picked up a bunch of old metal to scrap from a neighbor. Buried in the pile was an old water pump made by Leader Iron Works. It has "401" stamped on it. It has large pulley on it designed to be run off a motor. It spins freely. I really have no idea of it's age. My neighbor said he last ran it over 20 years ago to pump water from his pond. He had it hooked up to a 1hp electric motor at the time, but believes it was originally designed to be used with a hit/miss motor.
I haven't been able to find any information on it. I'm gonna try to get pictures of it up here today or tomorrow and hope maybe someone can help me identify it.
The Following User Says Thank You to linckeil For This Post:
Old 03-14-2016, 08:43:50 PM
Default Re: Leader Iron Works Pump
here's some pics. anyone have any information? guess on year?
ID:	248944   Click image for larger version
ID:	248945   Click image for larger version
ID:	248946   Click image for larger version
Old 03-14-2016, 08:48:06 PM
and a few more....
ID:	248951   Click image for larger version
ID:	248952   Click image for larger version
Old 03-15-2016, 07:53:51 AM
Doug Kimball's Avatar
Doug Kimball Doug Kimball is online now
Images: 77
Nice pump, I have not seen one like it before. I'd guess from the teens. Hard to tell from your photos just how big it is. Leader made their own engines and also used Stover & Rawleigh engines. If run by an engine the pump would normally have a tight & a loose flat belt pulley. Of course, someone may have later changed to the v-belt pulley.
In Kennebunk, Maine;
Doug Kimball
The Following User Says Thank You to Doug Kimball For This Post:
Old 03-15-2016, 06:02:32 PM
thanks for the reply. it is indeed a V-belt pulley as you observed. when where v-belts first put into use? that may help date it, but like you said, someone may have put on this pulley somewhere along the way.
so i got some more information. the pulley is 17" in diameter and the pump's overall length is 33". the only markings on the pulley read "15.4 P.D. B T"
other markings on the pump read "401", "100-2", and either "122" or "722".
It also says "LEADER IRON WORKS" "DECATUR ILLINOIS".
Lastly, "PAT. JULY 16 79". now is really looks like 16, but it could be 18 which would certainly make a lot more sense.
does any of this information help? someone out there must own a similar pump. is it odd to see a stand-alone pump like this? all other leader pumps i've seen are integral to a hit miss motor.
if anyone has any suggestions as to other websites that i should perhaps post this information on please let me know. thanks.
Old 03-17-2016, 05:24:26 PM
pulsechoes pulsechoes is offline
V belts as we know them came into existence in 1917, developed by John Gates of the Gates Rubber Company. V pulleys started in 1916, but the "belts" were leather.
The Following User Says Thank You to pulsechoes For This Post:
Leader Iron Works Engine Alan in KY Antique Gas Engine Discussion 8 06-19-2011 02:31:13 PM
What is it? Leader Iron Works Pump? Please Help! ryarbrough10 Steam Stationary Engines, Traction Engines, Steam Boats 6 02-23-2011 07:16:21 AM
Leader Iron Works 1 1/2 horse info needed Dave Beck Antique Gas Engine Discussion 6 03-02-2006 09:38:41 AM
Need information on Leader Iron Works engine. Scott L A-1 Machining Antique Gas Engine Discussion 0 01-23-2006 11:47:47 PM
Leader Iron Works engine Tanner Remillard Antique Engine Archives 8 04-24-2004 08:48:04 PM
