Propane tank/air pressure
this thread has 7 replies and has been viewed 4443 times
Old 06-29-2004, 02:29:46 PM
ihorse
Default Propane tank/air pressure
I have a couple of older Propane tanks--the ones they call 100pounders--they are ok--just out of date for the [gov't valve regulations]i want to use them to store air pressure-the question is---how much pressure would be reasonable??? thanks d,j,
Old 06-29-2004, 02:38:53 PM
William
Default Re: Propane tank/air pressure
I have one of those tanks I use for a compressor tank. I have my switch set to cut off at 120 psi. After about 25 years I haven't had any problems. I don't think I would pump much more pressure than that, because those tanks are not as heavy made as the compressor tanks.
William
Old 06-29-2004, 04:01:19 PM
Jerry Logan
Propane is at 120 psi
Old 06-29-2004, 05:38:23 PM
Ken Majeski
Propane pressure depends on Temperature. The higher the temp the more pressure you have. Propane will Boil at about 40 Below fairenheit... If it gets real cold up here Propane pressure can get so low you have No Heat. What amuses me is people are afraid of Steam Engines and air tanks but have a 1000 Gal Bomb sitting by their bedroom window... I would geuss the relief valve on Propane tanks is set at something over 200 PSI. I used one at 125 PSI for many years.... As with any tank with moisture in it you should UT or inspect it every few years....
Old 06-29-2004, 07:02:25 PM
Andre' Blanchard
A propane tank works just like a boiler, would say a propane tank is a boiler. Here is are some links to some info on propane.
http://www.weldingsupply.net/propane.htm
http://www.altenergy.com/propaned.htm
Looks like at 110°F a tank of 100% propane would be at 220psi and the critical point is 206.3°F at 618.7psia.
I know a guy that had a 500 gallon tank filled, they over filled it from a truck that had been sitting in a cool spot. When the sun hit the tank and the relief valve opened up there was foam running down the side of the tank, the pucker factor was real high for a time.
Andre' B. Clear Lake, Wi.
Old 06-29-2004, 08:38:16 PM
Andrew Mackey
Liquid Propane expands 5% for every degree F of rise, it is recommended that a tank not be filled more than 80% of capacity, to allow for expansion. Nominal pressure is 120# PSIG. The biggest problem using these tanks for air, is the condensation that will remain in the tank, and rust it. Typically, the wall thickness is about 1/8" vs 1/4" to 3/8" for a proper air tank.
Old 06-29-2004, 09:13:22 PM
Kid Dynamo
Hi D.J.- Propane tanks aren't the greatest for receivers but if I were going to use one for that, I would mount it upside down, tank opening down, after removing the tank valve.
In addition, I would incorporate a drop leg of some volume that was, again, straight down from the tank inlet. I would probably mount a cross-tee or at least a tee at the tank with my drop leg beneath that. Then put a blowdown valve at the extreme bottom of the drop leg to allow you to blow off any moisture.
The idea is to not allow the condensed water (which you WILL have) to stay in the tank and to have a place for some certain amount of this water to accumulate and still not enter the tank, and a way to easily and frequently get rid of it.
Any good air system has blowdown valves at the low spots of the pipework, as well. Propane tanks don't seem like they would tolerate moisture for any length of time without rusting.
If I had your money, I would just buy a A.S.M.E. approved tank, plumb it properly and not monkey around. You still have to follow good air system piping practices to avoid premature failure from moisture.
Old 06-29-2004, 11:16:06 PM
Vernon
Considering many of us used the old freon jugs for portable air tanks, (yes I know this is a no no), without any problems, you shouldn't have any problem either as long as you can get the moister out.
Onan 4k Propane Pressure Required? silverlake82 Onan Generators 35 09-10-2019 01:38:14 AM
Filling a Propane Tank From a Propane Tank Questions dalmatiangirl61 Fuels and Alternative Fuels 69 02-03-2019 11:04:04 PM
Kohler 7.5RH62 Propane Pressure G Sams Kohler Generators 4 04-14-2018 07:58:46 PM
12V Low pressure propane lockoff Kimbra Dean Generators & Electric Motors General Discussion 1 06-02-2012 10:14:32 AM
Propane pressure and starting Ray Griffiths Onan Generators 5 07-06-2010 02:02:07 PM
