Go Back   SmokStak > SmokStak® Antique Engine Community > Multi-Cylinder Stationary Engines and Power Units
Multi-Cylinder Stationary Engines and Power Units Waukesha, Buda, Climax, LeRoi and others.
old Hardie motor (engine?) Orchard sprayer...please help ID
this thread has 9 replies and has been viewed 410 times
Old 01-10-2019, 03:28:48 PM
Mistyinthemountains Mistyinthemountains is offline
Default old Hardie motor (engine?) Orchard sprayer...please help ID
So, if you saw my other post, you will quickly figure out I'm new at identifying a motor from an engine from a hit and miss...
I have two antique orchard sprayers, that much I know- this one is a Hardie Imperial XCXX (the other is a Super Bean LeRoi)
The sprayers were housed on the old farm next door..all is being turned to pasture.
I have the task of identifying them. This Hardie had an old oily canvas tied down over the cast iron..I moved it slightly to view. Please help me put the right name to the Hardie motor, engine, hit and miss...it is so cool and appears to have some original paint. I hope the photos help..can't thank you enough!
ID:	326066   Click image for larger version
ID:	326067   Click image for larger version
ID:	326068   Click image for larger version
ID:	326069   Click image for larger version
ID:	326070   Click image for larger version
Old 01-10-2019, 10:30:34 PM
John Schwiebert John Schwiebert is offline
Default Re: old Hardie motor (engine?) Orchard sprayer...please help ID
Hardie is the manufacture of the sprayer pump. Need better views of the engine. No neither this one or the other ones have hit & miss engines. I notice this one has a starter. The place I worked at sold Hardie sprayers and they were run from a tractor PTO. The hardie sprayers manufactures today are manufactured by a different Hardie company.
Old 01-11-2019, 11:50:32 AM
does this help?
Old 01-11-2019, 11:58:40 AM
Doug Tallman Doug Tallman is offline
Pictures of the side of the engine towards the pump and also from the front will help. Alos, any casting marks or numbers that you see. Some things I see in that picture remind me of a little Waukesha but there are other things different.
Old 01-11-2019, 02:10:27 PM
Tough to get at...hope this makes sense! I appreciate your insight.
---------- Post added at 01:10:27 PM ---------- Previous post was at 01:09:02 PM ----------
and this guy...
It all depends which way the sun is shining to get a photo!
Old 01-11-2019, 03:19:45 PM
If you haven't already, review some of the prior Hardie Sprayer threads here (a few are listed at the bottom of the page)...
As mentioned above, some did use Wauks little workhorse FC and possibly some of the FCs sister engines...I seem to recall one in which the engine had no radiator, but was plumbed to circulate its cooling water thru the water or whatever in the main tank...
If you get to the point of wire brushing the engine for stamped/embossed letters/numbers and still have no ID, you can send them to the Wauk Engine Hist Society (wehs.net) for an opinion...
Altho its "internal combustion engine" and "electric motor", engine and motor are terms often used interchangeably; hit-n-miss is a separate design (not an "inline" like yours) farm etc engine I'm completely foggy on myself...
Old 01-11-2019, 09:45:33 PM
PLCtech PLCtech is offline
Didn't we see something like this recently? Maybe a winch or something. Was it Continental or Hercules? I can't find the thread I'm looking for. I am only going from my memory of a picture because I know nothing about these engines.
Old 01-11-2019, 11:30:38 PM
Thank you!
Old 01-15-2019, 11:14:33 AM
Andy Williams Andy Williams is offline
looking at it i never saw a 4 cylinder on an orchard sprayer. but maybe i never saw one that big. i have a Novo CW, 2 cylinder that came off an orchard sprayer similar. this is not a novo. it could even be a replacement engine from a tractor. most of the old sprayers i have seen just had a one cylinder engine and most cushman cubs.
Old 01-15-2019, 01:36:55 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
We have an old Hardie Orchard sprayer that was used on our small orchard years back. It has the same motor under a factory hood to protect things from the elements and spray while in use. Also had the 3 cyl pump with porcelain lined cylinders and leather cups. As I recall it is indeed the little waukeshea for power, our was a hand crank and no radiator. Simply has a series of pipes in the bottom of the spray tank. They made several different sizes of units. Originally these all used the wooden cypress tank, if taken care of they would last a long time. The solutions used would eat up a steel tank in no time.
Hardie Orchard Sprayer jboyer1028 Antique Gas Engine Discussion 2 01-30-2018 09:06:46 PM
Hardie Orchard Sprayer kdrider Farm + Industrial Antiques and Collectibles 2 01-24-2018 06:54:52 PM
Hardie Orchard Sprayer kdrider Test Board 1 01-22-2018 11:41:18 PM
Hardie orchard sprayer Clifton McDaniel Antique Engine Archives 0 05-15-2004 05:00:05 PM
HARDIE ORCHARD SPRAYER Clifton McDaniel Antique Engine Archives 10 04-22-2004 04:04:13 PM
