CCK Contractors 569483 from Saint John NB
this thread has 31 replies and has been viewed 1583 times
Old 04-18-2017, 11:09:07 PM
DMeed DMeed is offline
Default Re: CCK Contractors 569483 from Saint John NB
Ahhh - so when the motor starts and spins the ring gear it spins the starter and disengages it.
Wonder why it won't move manually into the disengaged position?? Some kind of centrifugal clutch ?? Oh, well. Will have to try it.
Thank you for this info!
David M
Old 08-08-2017, 10:22:52 PM
Onanparts said: ICU2TVSET reports the following:
Model 5CCK-3P/1C and left the Onan factory 8-8-1957.
So this machine is 60 years old today. I reassembled and reinstalled the starter and spun it over.
Doesn't seem to have a lot of compression - when I spun it by hand I could hear hissing out the intake - sounds like intake valves not sealing tight?
I've been able to pressure wash away lot of dirt and most of the black spray paint is gone too. Now that I can see the machine it looks like someone has put two machines together.
The flywheel and the front cover look like they were blue at one time (and the starter has the blue paint on it too). It looks like someone took the flywheel and front cover with the starter off another machine and put them on this contractors cck which was likely manual start from the factory.
The coil added on the carburetor (seen in other pictures) is connected to the starting switch - so it appears someone put an electric choke mechanism on this to replace the manual choke. The start switch activates the choke as long as the machine is cranking.
David M
ID:	288232   Click image for larger version
The Following User Says Thank You to DMeed For This Post:
Another Cry For Help - Saint Louis Steam Engine Jim Alexander Steam Stationary Engines, Traction Engines, Steam Boats 3 02-22-2017 07:22:53 PM
Saint Mary's Gearless Larry K Antique Gas Engine Discussion 1 01-19-2013 12:21:50 AM
07-21-2012 Saint Marys Mike Monnier Antique Gas Engine Discussion 0 07-24-2012 08:53:26 PM
