Fairbanks Morse Diesel
this thread has 3 replies and has been viewed 716 times
Old 07-05-2019, 08:01:20 PM
David A. David A. is offline
Default Fairbanks Morse Diesel
need weight of a 60 hp Fairbanks verticle Y, thanks
Old 07-06-2019, 08:59:54 AM
Heins Heins is offline
Default Re: Fairbanks Morse Diesel
Could you post a picture of it?
Old 07-06-2019, 06:38:21 PM
Gene Williams Gene Williams is offline
I am not sure about the Y but most of the big Fairbanks with the big flywheel weigh 5 ton for the engine and 5 ton for the flywheel.
The Following User Says Thank You to Gene Williams For This Post:
Old 07-07-2019, 12:09:00 PM
Scott Hosack Scott Hosack is offline
One of my Fairbanks manuals lists the approximate shipping weight of 16,000 pounds for the 60hp. Depending on what flywheel and attachment options it could weigh in a whole lot more. My little 40hp vertical has a flywheel that must have been the special electric option as it is 8000 pounds all by itself. The outboard pulley and bearing setup are a big chunk that also add more weight to the engine.
The Following User Says Thank You to Scott Hosack For This Post:
Fairbanks Morse 36 A diesel 10 hp Jim McCracken Vintage Diesel and Oil Stationary Engines 13 12-02-2018 06:38:26 PM
Fairbanks Morse Diesel steve zane Unidentified Engines 5 12-28-2017 11:45:14 PM
Fairbanks Morse Diesel Jonah Close Vintage Diesel and Oil Stationary Engines 8 01-17-2014 07:24:42 PM
Fairbanks MORSE YH Diesel Carl Antique Engine Archives 0 07-29-2001 03:06:30 PM
Fairbanks Morse Y Diesel Carl Antique Engine Archives 10 06-21-2001 12:47:08 AM
