Help Identifying Electrical Gizmo
this thread has 4 replies and has been viewed 1184 times
Old 02-09-2018, 09:22:00 PM
oldironfever oldironfever is offline
Default Help Identifying Electrical Gizmo
good evening, we were cleaning out my grandpas shop this last weekend. he tinkered with small engines, tecumseh, briggs, etc... we found this gizmo there and was wondering if somebody could tell us what it is. it has a place for a mogul base light bulb the button on the side clicks when you press it. 2 red clamps for a hotside connection, 1 black clamp for a ground, and one 110 plugin ill try to get the pictures posted
ID:	302758   Click image for larger version
ID:	302759   Click image for larger version
Old 02-09-2018, 10:57:15 PM
Default Re: Help identifying electrical gizmo
Weird one.... maybe a test fixture for checking floresent lamps?
Doc
Old 02-09-2018, 11:23:22 PM
Default Re: Help Identifying Electrical Gizmo
its a timing light of sorts. I've seen them but don't remember exactly how it worked. you need the 110v to fire the light and it went off and on when the points opened or closed IIRC. Been too long ago.
Old 02-09-2018, 11:37:28 PM
radiodoc radiodoc is offline
I am new to Smokstak. I have followed it for sometime but just recently signed up so-to-speak. The item you have reminds me of what in the vintage radio/communications restoration is called a "dim bulb tester". The dim bulb tester is basically a plug, light socket, switch and clip leads. The bulb can be switched in and out of series. Initially the bulb is in the circuit and if it is dim then probably there is not a problem with the radio or device and for normal operation the switch shorts out the bulb. In restoring vintage radios this was/is used to protect scarce power transformers while testing.
The Following 4 Users Say Thank You to radiodoc For This Post:
Old 02-14-2018, 10:26:32 PM
dkamp dkamp is offline
eMail NOT Working
Actually, it looks like a large room humidifier to me...
why are you holding that thing in your hand?
Identify this gizmo? Siz Smokstak Down Under 13 08-11-2015 02:06:57 AM
What Does This Gizmo Do? Bob Naske Hit & Miss Gas Engine Discussion 5 04-21-2013 06:43:54 AM
UT Gizmo Dan Dyman Steam Stationary Engines, Traction Engines 2 04-27-2007 08:19:34 AM
