Welding Shop
Welder Identification Help and Info?
this thread has 13 replies and has been viewed 1182 times
Old 08-08-2018, 07:41:09 PM
Handyhiker1 Handyhiker1 is offline
Default Welder Identification Help and Info?
I went to look at this unit as I was told it was a generator. Turns out it is a welder. I don't know anything about welders but couldn't pass up the deal.
What I do know is it is a Continental F163 engine with a 175 amp DC Onan electric power head. Don't know the year or brand name it was sold as.
Would like to get a wiring schematic as a few wires are missing. The engine is not locked up and all the carburator linkage moved freely. These are the only pictures I currently have but will be picking it up on Saturday.
Any help greatly appreciated!!
Name:	Left side view.jpg
ID:	315981   Click image for larger version
Name:	Guage panel.jpg
ID:	315982   Click image for larger version
Name:	Radiator and hand crank - 1.jpg
ID:	315983   Click image for larger version
Name:	Welder head identification tag.jpg
The Following User Says Thank You to Handyhiker1 For This Post:
Old 08-08-2018, 07:43:20 PM
Default Re: Welder identification help and info?
A few more pictures.
Name:	F163 engine right side.jpg
ID:	315985   Click image for larger version
Name:	F163 left side.jpg
ID:	315986   Click image for larger version
Name:	Variable resister.jpg
ID:	315987   Click image for larger version
Old 08-08-2018, 08:33:10 PM
This looks.... Familiar.
Photo number three, second post, looks an awful lot to me like a voltage regulator. Further evidence that this set was not built as a welder generator.
Of course seeing that regulator hanging off the side of the machine, it's clearly not original so... The mystery continues!
Either way, it would be a fantastic set for someone "off grid" running a 24 volt battery...
Old 08-08-2018, 10:09:32 PM
radiodoc radiodoc is offline
Absolutely a wild guess but perhaps a power unit for some type aircraft while it is on the ground???
Old 08-09-2018, 02:06:02 AM
cobbadog cobbadog is online now
Default Re: Welder Identification Help and Info?
I cant see anywhere where there is a power lead outlet to be used as a generator set. I noticed the 2 terminals at the bottom on the left hand side for cables to be connected to but I don't see how it would be a welder. No voltage adjustment so I agree it is a power source for something but what?
Old 08-09-2018, 04:30:23 AM
It is a voltage regulator. It does have an ID tag on it but I don't have a picture of it. It was tucked in the unit but loose and has some clips on it where it could clip on somewhere. I pulled it out for the photos.
I will get more pictures Saturday and post them. Guess I bought something just not sure what.
Old 08-09-2018, 01:19:12 PM
Whatever it is, I think it's cool. I would have bought it too.
I'm looking forward to seeing what it does once it's running.
Old 08-09-2018, 01:56:29 PM
m_thompson m_thompson is offline
Google finds lots of 28VDC military generators available.
Nothing that matches your though.
The Following User Says Thank You to m_thompson For This Post:
Old 08-09-2018, 02:25:44 PM
I have been looking for a few days, nothing. Looking at welders and flight generators n
Old 08-10-2018, 06:42:10 PM
Question for the welding gurus on the forum. The rag on the Onan power head says 175 amps at 28.5 volts. Most welders that I have seen are 200 plus amp output. Is this a low output for a 4 cylinder welder?
I am really perplexed by what the real purpose of this unit was. Welder/generator/ground support? I have searched every way I can think of and just can't find another picture like it.
I will get more pictures and all info I can when I get it home tomorrow.
Old 08-10-2018, 11:38:50 PM
I don't know why I think this but I believe the 28volts is a bit low for an engine drive welder. For some reason 40volts is what I recalled. But I've been wrong before.
Old 08-11-2018, 08:01:51 AM
The more I look and try to research this unit, the more I believe it really is a ground support unit for aircraft. There seems to be quite a few that are 28.5 volt.
Not sure what I will ever use it for but it will be a neat project to try to restore.
Old 08-11-2018, 01:21:18 PM
Okay, the mystery is solved!! It is a Signal Corps PE 143-E and the serial number is 709. It does have Air Force on the top but could not read it till I cleaned it up a bit.
I cleaned off the tag on the front top of the radiator and found the other info. Sorry for the thread in the welding forum, it doors fab a label that says welding lead hook up but it is not an original label, that is what threw me.
Old 08-12-2018, 01:35:58 AM
Glad you have identified your new toy. It would be a nice display with some signals at a Rally and you will be about the owner person there with one.
If unsure what to do with it I would imagine that a Air Force museum would be interested in it.
Help! I need info on this Hobart welder Super-Rides Welding Shop 20 03-16-2018 02:37:08 AM
AIRCO Info gas engine welder OldironPhil Welding Shop 7 12-08-2016 09:51:14 AM
Antique welder info needed Brad Welding Shop 3 04-18-2010 10:08:36 PM
CP GW One Thirty Welder Info needed Don Smith Welding Shop 1 04-03-2008 11:31:13 AM
Info on airco arc welder Andy Williams Welding Shop 5 06-16-2007 01:30:20 PM
