Marvel no. 2 drag cut saw, WW2 Elwood Ordnance Plant
this thread has 7 replies and has been viewed 538 times
Old 04-26-2019, 08:10:21 PM
mschreiber mschreiber is offline
Default Marvel no. 2 drag cut saw, WW2 Elwood Ordnance Plant
This came as basket case, son and i figure it had major "tool hit work" collision that bent main shaft and damaged gear where u couldn't tighten it to the shaft. He made new shaft and made a "top hat" repair to the gear. Also put new main shaft bushing in it.
Video of it running reel good. https://youtu.be/6AMl37kPvEY
The Following 2 Users Say Thank You to mschreiber For This Post:
Old 04-26-2019, 09:23:10 PM
bartlett0815 bartlett0815 is offline
Default Re: Marvel no. 2 drag cut saw, WW2 Elwood Ordnance Plant
Dammit! Thanks to your video, now I've got to stop all my other projects and get my own Marvel No. 2 running. Seriously, thank you for the video. I bought one of these as a project for $60 a few years ago with the thought of "one of these days" and I was just looking at it a few hours ago before the sun went down. Mine has a 2 footish diameter flywheel, apparently for running it with a flat belt. I've already found and printed a manual from somewhere online. Do you have any good advice for do's or don'ts in getting these things going?
Thanks,
Kevin in NC
The Following User Says Thank You to bartlett0815 For This Post:
Old 04-26-2019, 09:59:51 PM
Do not let the tool hit the work! The slotted drive bellcrank allows you to make a long or short stroke. If you make a adjustment there MAKE SURE the new stroke does not hit ur work. The work holding vise is adjustable for this reason. good luck with ur project and lets see it running. i'm gonna look for flywheel marvels now!
Old 04-26-2019, 10:00:59 PM
I LOVE it! Repulsion motors are a favorite of mine, and I love seeing them with their old machines.
Old and obsolete? Beats the heck out of a hacksaw!
Old 04-27-2019, 01:21:23 AM
Thanks,
Kevin in NC
Marvel flywheel saw.
https://www.youtube.com/watch?v=K4-1eJb3QaU
The Following 3 Users Say Thank You to mschreiber For This Post:
Old 04-27-2019, 08:29:45 AM
I'm looking to trade this 1 for a belt drive flywheel model marvel power hacksaw.
Old 04-27-2019, 09:54:49 PM
I don't see any paint left on mine. Nothing but rust. Does anyone know the correct original color? I was thinking it was probably some sort of machinery gray.
Thanks,
Kevin in NC
Old 04-27-2019, 10:40:23 PM
Thanks,
Kevin in NC
right.
US Army Ordnance Battery Charger (12V Generator) dalmatiangirl61 Military MEP and Aircraft Gen-Sets 18 07-02-2013 02:11:14 AM
modern marvel James L Johnson Hit & Miss Gas Engine Discussion 0 01-30-2013 11:35:35 PM
Elwood's early Economy - Find, Haul and Restore Elwood Hit & Miss Gas Engine Discussion 37 02-20-2011 05:26:50 PM
Allen Elwood Ware -- South Carolina BMiller Old Engine Memorials 0 02-11-2008 01:10:16 PM
Marvel Mystery Oil Benny Mckheean Hit & Miss Gas Engine Discussion 0 05-03-2006 07:58:37 AM
