Go Back   SmokStak > SmokStak® Antique Engine Community > Propane and Natural Gas Fuel Delivery and Tuning
Propane and Natural Gas Fuel Delivery and Tuning Discussion about the care and feeding of Propane and Natural Gas Engines.
Wisconsin 4g4d Natural to LP
this thread has 3 replies and has been viewed 314 times
Old 06-11-2019, 11:36:09 AM
Mitbreese Mitbreese is offline
Default Wisconsin 4g4d Natural to LP
Hi folks, I now have a katolight generator powered by a 4g4d engine, it runs on natural gas but I need to convert it to LP. I have called the generator manufacturer and they are unable to help with any info. I have called numerous parts places and am having zero luck. Since it is already set up for gas wouldn't it just be a matter of an orifice change from natural to lp?
Thanks for any help/advice
Old 06-11-2019, 06:52:33 PM
Default Re: Wisconsin 4g4d natural to Lp
contact Wisconsin with all numbers from the engine and see what they say.supply reg. and demand reg. may need changed.also maybe ig. timing change and plugs and gap.
Old 06-12-2019, 03:07:51 PM
Thanks for the reply....I have tried to contact them at wiengines.com and I get website unavailable. I cant find any other contact info in a Google search.
Old 06-12-2019, 09:49:41 PM
dkamp dkamp is offline
eMail NOT Working
Default Re: Wisconsin 4g4d Natural to LP
Going from NG to LP, you'll need LESS LP, as the NG fuel has a fair amount less BTU energy than the LP.
You won't likely need to replace orfice... mebbie a little adjustment to timing... the fuel pressures and demand regulator should do it, and perhaps trim back the 'power' adjustment a bit.
When a gaseous fuel engine runs, it acts like it's lean when it's rich... it'll act lean. When it's lean, Itll act rich.
Wisconsin TJD Questions About Converting To Natural Gas The Doctor Wisconsin Engines 0 08-09-2018 04:03:51 AM
Wisconsin 4G4D Weak Spark: help! Jeff6566 Wisconsin Engines 12 03-14-2018 02:18:50 PM
Wisconsin THD natural gas generator MXB Generators & Electric Motors General Discussion 9 04-24-2013 10:36:53 PM
CCK and Natural Gas J. McNugget Onan Generators 7 09-09-2009 10:46:54 PM
