Vintage Electric Hair Clippers
this thread has 10 replies and has been viewed 670 times
Old 05-16-2019, 01:02:00 AM
Default Vintage Electric Hair Clippers
After looking through all of the forums, this is the closest I felt I could find to ask about these.
I want to buy a vintage set of electric clippers, but know nothing about which brands or models might have been better.
Generally, I like the ones I have seen that are made of polished aluminum castings, and employ the vibrating linear type of motor. A linear reluctance synchronous motor, if I had to guess what it might be called. Like in an aquarium air pump. Not a rotary motor driving an eccentric, like a hedge trimmer.
Are there any vintage barber shop equipment collectors here? Would that be called "Barberana" lol?
Thanks,
Old 05-16-2019, 01:41:53 AM
Default Re: Vintage Electric Hair Clippers
I bought an Oster. Works and sounds like the ones I remember from the barber shop. Has been a decade or so, so don't know if they are the same. Only complaint is I have to keep cutting head fully oiled because cutters are plain steel.
Doc
Old 05-16-2019, 06:09:14 AM
BobSaunders BobSaunders is offline
I have a old Oster 76 clipper. The round cord has the rubber all cracking. Still being made today. I should replace the cord and maybe find it a new home.
Old 05-16-2019, 06:48:39 AM
OttoEngineMan's Avatar
OttoEngineMan OttoEngineMan is offline
!908 Koken Barbers Chair removed out of its original installation in Bettsville, Ohio. I am not into barbers things, however the condition and rarity of this chair made me have it...
The Following 2 Users Say Thank You to OttoEngineMan For This Post:
Old 06-13-2019, 02:33:19 AM
Here's what I ended up getting...
How do I best go about sanitizing this?
ID:	337041   Click image for larger version
ID:	337042   Click image for larger version
Old 06-13-2019, 03:20:29 AM
Nice score Keith.
Dissasemble head and soak it in alcohol would be my suggestion.
Doc
Old 06-13-2019, 09:20:02 AM
Isopropyl alcohol for the final wipe clean of all the bits after it has been fully disassembled. However, there is a sterilising solution for barbers — "Barbicide".
https://en.wikipedia.org/wiki/Barbicide
Good quality clipper oil is available in most places, farm shops may have larger bottles.
The Following User Says Thank You to Radiomike For This Post:
Old 06-13-2019, 11:44:57 AM
Yes, Barbicide. I've always marveled at the bravery of barbers having that stuff right next to where they're working!
Old 06-13-2019, 11:57:54 AM
After cleaning be sure to oil it! if you dont, atmospheric humidity will rust the cutting assembly! if you dont plan to use it, some 3 N 1 electric motor oil will work - it wont oxidize and cause sticking. if you plan to use it, there is a special clipper oil.
Old 06-14-2019, 04:31:56 AM
NDmeterman NDmeterman is offline
If looking for isopropyl alcohol, try and find the 99% stuff. Drug store rubbing alcohol is usually 70% or 90% (the remainder being water and other things).
Some fuel system de-icers are nothing more than 99% isopropyl alcohol.
The Following User Says Thank You to NDmeterman For This Post:
Old 06-26-2019, 02:49:52 PM
Tracy T Tracy T is offline
funny story i herd involving a barber chair, neighbours out the road have one in their farm shop. well one of the brothers cant handle his booz, they had installed a seatbelt unknown to said brother. he got out of hand one night and passed out in the barberchair. the older brother said belt him in so he wont fall out. when he came to i reckon is was one sight him trying to figure out just why in the hell he couldnt get out of the chair. I would have loved to been there to see that!
Master Electric Co. AC Motor Vintage klerew Generators & Electric Motors General Discussion 1 01-21-2017 04:46:20 PM
Vintage Westinghouse Electric Motor metalist Generators & Electric Motors General Discussion 22 03-02-2016 10:39:27 AM
Vintage Westinghouse Electric Motor metalist Generators & Electric Motors General Discussion 10 12-06-2015 08:05:04 PM
Vintage Sears 3000 electric start zor Generac Generators (SEARS, etc.) 8 10-24-2015 07:47:16 PM
vintage General Electric motor PeterMoses Generators & Electric Motors General Discussion 9 01-12-2012 08:10:52 AM
