Located an ONAN 15JC3R-3992K
this thread has 17 replies and has been viewed 1943 times
Old 05-08-2012, 12:16:24 PM
dansonan dansonan is offline
Default Located an ONAN 15JC3R-3992K
HI Guys thanks for the help along the way
I found a hopefully good one at a great price 800.00 plus shipping @300.00
Its a 15JCR-3992K Serial number is 64C770442
I called Onan and they did a quick parts check and I asked id piston rings head gaskets are availble.. THEY SAID YES
So I want to ask here is this a good one to get ..?
THANKS for the info and letting me kow anything you can about this motot
a guy told me to use my land line with a amp meter to see the LOAD I am useing But I hope you all agree this will work... DANiel
Old 05-08-2012, 01:35:23 PM
Kevin K Kevin K is offline
Default Re: Located a ONAN15JC3R-3992K DANSONAN
Made in June 1964, from the serial number.
Are you sure the model number is correct? There should be a number following the JC, giving the voltage code. For example, 15JC-3R/3992K or 15JC3R/3992K would be 120/240 volt. Could you contact the seller and ask for the correct model number? You would not want to wind up with something unusable because you weren't given the correct model number.
Old 05-08-2012, 01:49:42 PM
I asked in the other thread if your ice cream machines are single or 3 phase? Many ice cream trucks had 3 phase machines for some reason.
The model number 15JC is a 15 kw gasoline JC 4 cylinder air cooled engine
next should be a 3C or 18 code or something similar followed by the "R" for remote start capable
If the serial number given is correct it is a early production version build spec K which would make it a magniciter gen end. The JB/JC's were made from early 60's to 1991 or so.
The JC's are a good reliable machine and most parts are still available from various sources. Some magniciter components are getting scarce.
Ask for complete data plate info and if possible a clear photo of the data plate. Then we can tell you what it is for certainty.
There are several 3 phase JC's in the new york area on fleabay at a high price. And I've found several others in New England on C/L /some diesel . some gas.
Old 05-08-2012, 02:30:04 PM
My fault ...!
model number is 15JC3R-3992K SEIAL IS 64C770442
Thanks for letting me know if this is a good one for my 220V Single phase pluse the 110v fridge a/c and slush puppie machines plus some misc low watt like th lights music box I do have a micro wave taht might get use for no more than 1 min.. at a time... if that
DAniel
---------- Post added at 02:30 PM ---------- Previous post was at 02:16 PM ----------
I forgot to ask here he says this is 4ft 7 inches long and 32 inches deep
If you can tell me dimmesions and weight that would be a big help Thank-you again DANiel
Old 05-08-2012, 02:44:25 PM
You might consider giving us a few more details on your vending truck. Such as:
The make, model, voltage, current, and wattage of every load.
Does the truck have a dedicated generator area? How large?
How do you intend to use the truck? Pull it to events for a day? Park it at a location and use it every day? Every weekend, or just once in a while?
This generator is quite large, rather heavy at 825 Lbs, and quite thirsty at full load: 3 Gallons Per Hour propane or 3.5 Gallons per Hour gasoline. Now is the time to think about how you are going to house this generator, how many hours you are going to use it, and how you are going to keep it supplied with fuel.
---------- Post added at 02:44 PM ---------- Previous post was at 02:39 PM ----------
Onan 15JC3R generator
Length 56"
Width 20"
Height 29"
Weight 825Lbs
Old 05-08-2012, 03:11:20 PM
My camera crashed , but here are some pictures of the Ice cream truck and the Onan CW
I talked to a guy here that a Big help with his knowlage on these truck ( R*ber* Mar* ) he tells me the JC is the way to go for my power needs becuase the Ice cram machine need at least 6k A/C roof 1500 fridge 1500 slush 1500 plus the extras
I will have to modify the wheel wells to get it in
I noticed my CW uses pretty mch gas also but if I can use all my machines not just only 2 like I am I should be able to have teh gas paid for
I plan on saling Ice cram from 6 in the evening to 9 or 10 every night but week ends I migh use it for 6 to 8 hrs a day.
some jobs I can use a alnd line .. Thanks again DAniel
ID:	134904   Click image for larger version
Old 05-08-2012, 03:15:05 PM
Sorry, make that about 2.5 Gallons per Hour of gasoline, and 3 gallons per Hour of Propane, if it's set up for propane.
Old 05-08-2012, 03:52:54 PM
thanks for all the help I just bought the Onan 15jc3r-3992k serial #64c770442
If someone could please send me a link to a owners manual (ones on the Way but like to get a head start
Thanks again for the help DANiel
Old 05-08-2012, 04:08:42 PM
John Ward John Ward is offline
would a 20-25hp diesel be better than two gasoline gensets for his situation?
Old 05-08-2012, 05:59:08 PM
looks like a Mr Softee built franchise truck. They were all built with the 10 CW's as power plants
The weight of the JC will be very close to the CW.
Send me a PM with your e-mail address and i'll send you the JC with the magniciter gen end manual
Ed
Old 05-08-2012, 07:45:08 PM
I hope it works out. Looking at the “Model Identification” chart for units prior to 1969 lists a voltage code 3 as 120 – 240 single phase 3 wire.
Old 05-08-2012, 08:08:16 PM
bobbyz72 bobbyz72 is offline
how much you want for the cw?
Old 05-08-2012, 09:46:19 PM
I was wondering how long that would take BobbyZ
Old 05-08-2012, 10:55:23 PM
thanks for the manual send to
darrendog@hotmail.com
as for the CW I think I will use it for a back up in my shop it would be great for regular usage just hard for lots of heavy compressors. etc..
DAniel
Old 05-08-2012, 11:18:20 PM
Check your e-mail for 967-500 JB/JC magniciter manual.
The Following User Says Thank You to Ed Sparks For This Post:
Old 05-09-2012, 08:41:23 AM
ED Thank-YOU for sending the file ! really appreciate it!! Is there a operating sheet for starting and running this JC . And if this is available.. to send.
Thank-you I am going to change the Oil when I get it looks like 30 weight non detergent the plugs H-*
unless you have a better suggestion (s) And if you could please let me know if I should do any other preventive maintenance before I install this in the truck
My plan is to go over this before I remove my CW and start this on the ground and make sure all my Equipment runs like it should ..
Thank-yo Ed again and "ALL" ...DANiel
Also if you can tell me since this is 15kv what is the surge kv (reserve) power for start ups on my refrigeration compressors Thanks DANiel
Old 05-09-2012, 11:09:49 AM
Ted_Cool Ted_Cool is offline
Don't worry about the ancient oil recommendation. Get some 0W-30 - I use Mobil One.
While you're going over it, consider replacing the points with the Pertronix ignition module. This is the #1 part to make it run reliably.
Good luck!
Old 05-09-2012, 06:13:22 PM
Kimbra Dean Kimbra Dean is offline
Default Re: Located an ONAN 15JC3R-3992K
Does the JC have vacu-flow cooling? If not it may be a little more difficult To keep the generator cool in this compartment
The Following User Says Thank You to Kimbra Dean For This Post:
Onan Parting Out Thread (Used Onan Parts only!) Wayne 440 Onan Generators 820 Yesterday 11:55:59 PM
Where are you located? Chris J Smokstak Forums Meet and Greet 474 10-10-2019 04:38:46 PM
Cummins or Onan engine on Onan 20DL4?? fluegas Onan Generators 8 01-11-2013 12:48:02 PM
Insurance for steam traction engine (located in Canada) Raymond Rae Steam Stationary Engines, Traction Engines 10 05-04-2007 07:45:48 PM
Which State were manufacturers located in? Mike O'malley Antique Engine Archives 6 09-28-2004 11:04:45 PM
