FB Buzz Saw
this thread has 8 replies and has been viewed 1480 times
Old 03-01-2013, 01:27:50 PM
AKMark AKMark is online now
Default FB Buzz Saw
So I drove to down to California and delivered my Massy Harris 81 tractor to the man who bought it. While I was there I picked up this buzz saw, the engine is a FB Z B 5 HP. I am going to have to rebuild the saw frame and the engine is running off a coil and battery. This is going to be a fun project
Name:	buzz saw 1.jpg
ID:	159301   Click image for larger version
Name:	buzz saw 2.jpg
The Following 4 Users Say Thank You to AKMark For This Post:
Old 03-01-2013, 02:44:33 PM
ehpower2's Avatar
ehpower2 ehpower2 is offline
Default Re: FB Buzz Saw
very interesting way that the flywheel is connected to that buzz saw very unusual
Old 03-01-2013, 03:10:06 PM
I don’t know if it was factory or home built but a picture from my 1908 FM catalog shows one on the blade shaft. The man I got it from built the trailer frame but never put axels on it. It came from the coast and the salt air has rotted it bad but the bearings and grease cups all look good. Do you have any pictures of other examples of the frame? Thanks!
Old 03-01-2013, 03:32:06 PM
73eldo 73eldo is offline
Is there another pulley or gear or anything on that lower shaft? Or is it just the one pulley and flywheel we can see?
Just wondering if it was maybe for some auxiliary piece of equipment?
Old 03-01-2013, 04:23:40 PM
Exclamation Re: FB Buzz Saw
Engine was built for export - the red flywheels are a dead giveaway. All the FM Z engines I have seen, painted in this color scheme were built in the USA and were exported to Canada. I have seen at least 6 of them, mostly the 6 HP versions, all came back to the US, and 5 of them were in NY state.
Old 03-01-2013, 04:24:07 PM
No just the one pulley and flywheel. And now that you mention it doesn’t make sense. The engine drives the top shaft so why the bottom shaft and flywheel? I will have to ask him he said he had been using it to cut fire wood for years.
Old 03-01-2013, 06:18:20 PM
Dick Graybill's Avatar
Dick Graybill Dick Graybill is offline
If the flywheel is on the saw shaft it would restrict the size of wood being cut.Just a thought.Dick.
The Following 2 Users Say Thank You to Dick Graybill For This Post:
Old 03-01-2013, 08:29:41 PM
My father, bless his 83 year old heart said that’s the way it’s supposed to be. He said it’s to keep the momentum up while sawing.
Old 03-01-2013, 09:13:52 PM
That's right, it keeps the flywheel out of the way for long logs.
Buzz Saw MD4302 Farm Antiques and Collectibles 22 04-15-2013 10:23:29 AM
Buzz Box Help Jim Alexander Magnetos, Ignition Coils and Spark Plugs 9 11-02-2012 08:28:48 PM
Need a Buzz Saw? Tim Claremont Hit & Miss Gas Engine Discussion 10 02-09-2009 09:24:27 PM
Buzz Box Rich Lehr Hit & Miss Gas Engine Discussion 3 03-06-2006 08:22:37 PM
how to buzz a FMB Z RHudson Hit & Miss Gas Engine Discussion 5 12-14-2005 05:33:25 PM
