Oil Field Engines
Bovaird Seyfang 40 HP
this thread has 1 replies and has been viewed 1280 times
Old 06-25-2013, 08:36:20 AM
Tom Poole Tom Poole is offline
Default Bovaird Seyfang 40 HP
Hello All
I have a 40HP Bovaird Seyfang. I am having a little trouble fine tuneing it. It miss fires quite a bit. Any help is appreciated.
Thanks Tom
Old 06-25-2013, 11:23:32 AM
Fred Van Hook's Avatar
Photo Re: Bovaird Seyfang 40 HP
If it back fires every once in a while the timing need advanced just a little. Doesn't need a lot of fuel and restrict the air to very little. If yours has the intake box on top close the gate to less than a 1/4 inch. If you can put it under a load they run great.. Here is a movie of the one I used to have..
A Atheist will never be able to say, "I told you so!!"
Engine movies can be seen at: pileofiron
Bovaird and Seyfang Chris Austin Oil Field Engines & Related Equipment 2 12-25-2010 10:52:37 PM
40 H.P. Bovaird & Seyfang Jeff Miley Hit & Miss Gas Engine Discussion 3 03-13-2008 08:25:36 PM
40 H.P. Bovaird & Seyfang Fred Van Hook Oil Field Engines & Related Equipment 3 01-09-2008 07:31:05 PM
Bovaird And Seyfang SteveK Oil Field Engines & Related Equipment 0 08-30-2007 09:20:37 PM
40 hp Bovaird & Seyfang $$$ ? OLDREDIRON Antique Engine Archives 1 09-25-2004 07:08:21 AM
