Onan 200amp 3 Phase 120/208 transfer switch. Can it be converted to single phase?
this thread has 12 replies and has been viewed 3113 times
Old 07-13-2013, 08:52:10 PM
jefffurness jefffurness is offline
Default Onan 200amp 3 Phase 120/208 transfer switch. Can it be converted to single phase?
I posted about a EM 40 Onan my father and I have. We had it coverted to single phase 120/240 so the three phase switch we have won't work when we set it up. Can the switch I have be converted to single phase 120/240?
Name:	013 (800x600).jpg
ID:	169494   Click image for larger version
Name:	012 (800x600).jpg
ID:	169495   Click image for larger version
Name:	011 (800x600).jpg
ID:	169496   Click image for larger version
Name:	010 (800x600).jpg
Old 07-13-2013, 09:34:38 PM
Billy J Shafer's Avatar
Default Re: Onan 200amp 3 Phase 120/208 transfer switch. Can it be converted to single phase?
It could be but you will have to change some of the 208 relays.
Old 07-14-2013, 12:15:05 AM
Gunny Gunny is offline
Yes but......
You would be changing some of the relays, if you can find them. Onan no longer provides support or carries repair parts for that switch.
In it's day, that switch was the best available. Compared to today's product, not so much.
If it were me, I'd consider a manually operated switch, far less expensive and not likely to malfunction or get damaged by lightning. If you do need an automatic, look at ASCO or TTI (Thompson Technology).
Consider selling your existing switch as parts on ebay. Probably greatly off set the cost of a new switch. Most of the parts inside are no longer easily available. For instance, the main contactor.
Old 07-14-2013, 12:41:11 AM
The transfer pilot relay. Is no longer in the system. Last one I converted. Relays and labor was over 1500.00 dollars.
Old 07-14-2013, 07:33:14 AM
+1 for a manual switch. It is hard to beat a big old manual (such as Square D) switch that makes a satisfying "clunk" when you pull the handle. They are not the least expensive brand, but such a switch may last 50 years, and there is not much short of a direct lightning strike or significant external physical damage that will break it.
If you want an automatic, a quick Google seach reveals that a new residential grade 200A automatic switch, such as an ASCO 185 can be had for well under $1500.
Old 07-14-2013, 08:24:53 AM
At what voltage are the pull in coils rated? 208 vac?
If you have 240 vac, and have 208 vac coils they would work but maybe overheat. What about a blocking resistor to drop the 240 to 208 vac to run the coils?
This is they way I think, I try to determine how it functions and see if I can make it work.
Old 07-14-2013, 10:46:52 AM
Good ideas. But that is a 1972 switch. Most of the parts on the swing out door. Can be replaced. But if anything on the contactor goes out. You can trash it. I tried to buy a interlock coil twenty years ago. No longer in the system.
Be much better off buying a new switch.
Old 07-14-2013, 02:55:56 PM
Richard L Richard L is offline
I converted a LTU 3 phase to 120/240. What I found is that most of the controls operated off of 120/240,you just had to figure what contacts went where. If I remember correctly, I had to change some jumpers on the transformer that was used in the control system.
I just picked up a OTPC 125 a switch for $50.00 on Ebay that is a newer switch,you might try ERIC at GOLAND 610-658-3242 and see what he has,as he was the person who had this on E bay
R
Old 07-14-2013, 08:03:01 PM
Thank you everyone. This forum is great!
Old 07-14-2013, 08:31:52 PM
Daverepair Daverepair is offline
I have the inner panel to a LTD, I think, switch that may have a relay or two on it @240 vac. I will check it out and if so you are welcome to it for the price of shipping.Do you have a manual or wiring diagram for your switch
Old 07-15-2013, 04:05:31 PM
No manual. Thanks for the offer.
Old 07-15-2013, 05:40:13 PM
MBB MBB is offline
Post an email and we will get you a manual.
Old 07-16-2013, 03:09:28 PM
jefffurness@hotmail.com. Thank you!
Single phase generator with 3 phase transfer switch? mixdenny Onan Generators 5 06-04-2014 08:26:01 AM
Convert Onan 5.0CCK-5DR/8462V Three phase to Single phase RichardD Onan Generators 4 06-29-2011 07:48:56 AM
Onan 15.0JC wiring change from 3 phase to single phase? Danile Onan Generators 6 03-11-2011 06:00:28 PM
Three phase Transfer switch to single phase tunafishhkg Kohler Generators 5 10-26-2010 01:48:42 PM
3 phase to single phase for a Onan 15JC ksmith05 Onan Generators 9 01-03-2009 02:46:58 PM
