Go Back   SmokStak > SmokStak® Antique Engine Community > Hit & Miss Gas Engine Discussion > Unidentified Engines
Unidentified Engines Post your photos and questions about your unknown engine and look for answers here.
Unknown small engine help?
this thread has 12 replies and has been viewed 2300 times
Old 07-23-2013, 07:33:27 PM
Mike Shaffer's Avatar
Mike Shaffer Mike Shaffer is offline
Default Unknown small engine help?
I have had this small water cooled engine for a while and would like to see if anyone can identify it. It stands about 14" tall with a 7 1/4" flywheel. It has a two piece crank case like a bike engine that is about 3 1/2" wide. Schebler carb and a Berling AOS mag. The same mag a Smith Motor Wheel used. Being water cooled I ruled out a bike engine. Possibly a small cycle car engine? Your thoughts.
ID:	170300   Click image for larger version
ID:	170301   Click image for larger version
ID:	170302   Click image for larger version
The Following User Says Thank You to Mike Shaffer For This Post:
Old 07-23-2013, 07:35:52 PM
Default Re: Unknown small engine help?
One more picture.
Old 07-23-2013, 09:22:00 PM
what am I looking at behind the pulley?
Old 07-23-2013, 09:28:59 PM
Junkologist's Avatar
What you have is a very rare early water-cooled Gravely model D garden tractor engine.
Mike
SmokStak member #146
The Following 2 Users Say Thank You to Junkologist For This Post:
Old 07-23-2013, 09:38:29 PM
Thanks Mike. Now I know. Do you know what years they were produced?
Old 07-23-2013, 09:49:03 PM
I think they were produced around 1925 or so.
Mike
Old 07-24-2013, 08:31:37 AM
Do you know if Gravely built the engine, or was it built by someone else and used on the tractor?
Old 07-24-2013, 09:39:13 AM
Emil K Emil K is offline
That is kind-a-of a cool little engine Mike.......will it run?
The Following User Says Thank You to Emil K For This Post:
Old 07-24-2013, 09:48:29 AM
Hi Emil,
I am not getting a spark from the mag. I checked the magnetism in the magnet and it has none. When I got the engine it was setup on a cart with a cooling tank. I know it had run in the past by the previous owner.
But to answer your question, no I have never ran it.
Good to hear from you again.
Mike
Old 07-24-2013, 04:11:45 PM
As far as I know, Gravely built the engine. I believe I read once that the first prototype tractor that Benjamin Gravely built used an Indian motorcycle engine and that's why the Gravely engines have such a resemblence to a motorcycle engine with the flywheels inside the crankcase.
Mike
Old 07-24-2013, 05:39:12 PM
Now I am really confused as my engine has an external flywheel.
Old 07-24-2013, 07:28:00 PM
I googled Gravely model "D" and was reading some threads. They were talking about the serial numbers on the side of the block. I took the fuel tank and bracket off of mine and revealed the embossment where the serial number is supposed to be and mine is blank. i am wondering if all these engines were used on walk behind tractors.
Old 07-24-2013, 07:54:40 PM
Redwing Redwing is offline
nice motor.
I found in search .. yup flywheel is early one.
go look
http://www.gravelyguy.com/gravely-tractors.html
see first 4 photos (before and after restore). you can see flywheel there on other side.
The Following User Says Thank You to Redwing For This Post:
Unknown Small Engine flywheelerjohn Small Air Cooled Gasoline Engines 5 07-04-2013 02:06:23 PM
Unknown Small Engine? HELP! Toms Tractor Small Air Cooled Gasoline Engines 4 04-29-2013 10:03:47 AM
Unknown Small Engine oldironpeddler Unidentified Engines 3 08-01-2012 08:54:06 AM
Unknown small engine Kent Churchill Hit & Miss Gas Engine Discussion 11 10-21-2008 05:27:36 PM
Unknown small engine Bert Juffer Hit & Miss Gas Engine Discussion 12 09-19-2005 04:33:49 PM
