Onan 7HGJAE type B, error 3 code 15
this thread has 0 replies and has been viewed 3679 times
Old 09-03-2013, 06:07:16 PM
sdetweil sdetweil is offline
Default Onan 7HGJAE type B, error 3 code 15
reading another topic, it seems I may have one of these failed rotors
this is the vertical engine shaft and generator rotor.
should I be able to turn the rotor by hand?
I would expect the belt to be tensioned against the engine.
I am getting fault code 3, error code 15. (under voltage), and the engine stops.
the rotor tests fine with my limited tools, about 32 ohms. (not exactly 31.97 per spec in 983-501).
need to test the stator, but I'd be really surprised that a static element could fail like this. 4150 hours.
but a belt could fail, and the rotor would turn.. but removing the base plate ain't easy.. got to get my engine hoist out again.
(you would think they would make the belt accessible without having to disassemble the thing)..
thanks far any advice
ONAN 7HGJAE-2132 vs 7HGJAB-900 munder0000 Onan Generators 2 07-05-2013 08:10:37 PM
Onan 7HGJAE-2132 Generator - Need normal oil consumption rate lancew Onan Generators 4 02-17-2012 08:15:06 AM
Onan 200DSHAC-6728 Spec: C / Error Code 235 LOW COOLANT LEVEL SupermanSC Onan Generators 10 12-02-2011 09:35:01 AM
Choke assembly for an Onan 7HGJAE-2132A lancew Onan Generators 2 11-20-2010 08:34:30 PM
4K Microlite 36 Error code,Mdl #4KYFA Hasty Onan Generators 4 07-30-2009 07:24:37 PM
