Predator Generators
this thread has 168 replies and has been viewed 118614 times
Old 07-05-2019, 05:41:02 PM
Motormowers's Avatar
Default Re: Predator Generators
Based on the 4 five gallon pails full of dead carbs in my shop I think a good cause would be the carb needle sticking and flooding the cylinder causing the hydro lock. Or maybe the end bearing on the generator seized up.
Remove the all rotten apples out of your basket of life and toss them in the trash where they belong.
The Following User Says Thank You to Motormowers For This Post:
Old 07-05-2019, 06:06:48 PM
Thank you for suggestion, but have pretty much eliminated hydrolock as a possibility. Generator was run dry. Fuel poured in tank and rope pulled. Turned over a few revs, then locked solid. Not enough time to develop hydro lock between pulls.
More likely is something like my drain magnet getting loose inside and sudenly jaming in cam drive gear. Next possible.... rotor lamination broke and suddenly shifted locking rotor to armature.
Just guessing at the moment though.
Doc
Old 07-06-2019, 01:03:00 AM
If you remove the rewind can you spin it backwards??
Old 07-06-2019, 01:42:18 AM
Without a rod thru the block, it probably has some more life, even if it just as a parts donor
Machinery is funny the way it fails, was mowing (tall) grass a few days ago and found some lost cones, but everything kept working so I kept mowing. Started it up yesterday and tried to mow, but it no mow, shear bolt was missing on input to pto
The Following 2 Users Say Thank You to dalmatiangirl61 For This Post:
  #165
Old 07-06-2019, 10:12:03 PM
Doc, This is very interesting. I wish we could get a autopsy video or still picture post as each part is dismantled.
The genset Steve gave me has rusted, unavailable stator bolts. I decided to snap them and use threaded rod to put it back together. I wanted that end bell bearing to be well greased. If they lock, The damage is usually always fatal to the generator end.
Robert
Old 07-08-2019, 11:37:19 PM
Okay folks, here is facts on bound up Predator gen. Handyman says he was able to turn motor backwards, which curred bind. So likely chunk of something binding in crank to cam gears. He said it had also picked up a knock. So my thinking is a piece of rod bearing cap broke off and got up into gears. He will watch drained oil for chunks. With rod knock that pretty much retires engine. I'll keep it around as a backup, or sell it off for like $100 with a full disclosure to any buyer.
He did verify it wasn't my drain plug magnet, so busted rod cap is about only thing I ca think of where binding chunk came from. That is supported by sudden knock sound.
Doc
UPDATE: Final hour reading 5564.6
Old 07-09-2019, 11:59:02 AM
Maybe parts from the decompression mechanism
Made of plastic on some cloners, not sure on the predator..
I'd say you got your $$'s worth out of it.
Add: Generator version should be metal, still a possible (probable, I'd say) source of loose bits.
Old 07-09-2019, 06:05:05 PM
Glenn Ayers Glenn Ayers is offline
I think ..........................................
If it locked up on "Starting rotation" ... but it would then turn the other way ..............
I'd be looking for something on top of the peeeston.
"I'll have the Red Pill, thank you."
Old 07-09-2019, 06:21:07 PM
Email NOT Working
I had an abused Honda once that would lock on forward slow rotation but spin backwards fine. Not locked up all at once but a little bit like overwinding a clock spring. Since we did not care much about it I spun it with a drill motor on the crankshaft nut and forced the thing to start! Then I gave it back to the guy and he never complained. But I don't know if he used it much either.
After further experiences I now believe it may have been a ball bearing going bad. Probably the end bell bearing. But we will never know for sure. But I did have a CCK do the same thing and was able to fix it with an end bell bearing.
Old car Generators as Starter/generators dhiesel Small Air Cooled Gasoline Engines 7 07-18-2012 01:41:03 AM
Syncing two generators or sinking generators James Storm Generators & Electric Motors General Discussion 7 03-03-2010 04:45:15 PM
Anyone know about Hol-Gar generators? DaveBos Generators & Electric Motors General Discussion 13 11-29-2007 11:02:17 AM
Generators George G. Fries Generators & Electric Motors General Discussion 5 08-22-2004 10:18:38 PM
