Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Diesel and Oil Stationary Engines
Vintage Diesel and Oil Stationary Engines Fairbanks Morse, Lister, Petter, Witte and other pump injected Diesel oil engines.
Fairbanks Morse Diesel
this thread has 8 replies and has been viewed 3302 times
Old 12-30-2013, 01:03:15 PM
Jonah Close's Avatar
Jonah Close Jonah Close is offline
Default Fairbanks Morse Diesel
Does anybody in stakland have any information on this particular engine? How many exist? Value? Thanks!
The Following 8 Users Say Thank You to Jonah Close For This Post:
Old 12-30-2013, 02:18:01 PM
Scott Hosack Scott Hosack is offline
Default Re: Fairbanks morse diesel
I believe that is a Fairbanks Morse 36A diesel engine. I think that they built them in 5 and 10Hp per cylinder? That is all I really know about them.
The Following User Says Thank You to Scott Hosack For This Post:
Old 12-30-2013, 03:30:39 PM
enginenut2 enginenut2 is offline
As Scott says, In the Diesel Engine Catalog , volume 2 (1937) the Model 36A is described and pictured in several configurations.The smaller in 1,2,3,4,6 cyls of 4 3/4 x 6 dimensions at 10 HP per cyl. The larger version in 4, 6, 8 cyl 0f 5 1/2 x 7 1/2 dimensions at 15 HP per cyl (this was rerated to 20 HP per cylinder in the volume 8 (1943) catalog) and an eight cyl was added in the smaller engine. The small one was called the model 36A4 1/2 the larger was model 36A5 1/2 . The large one was shown to be convertible to GAS. The model 36A was not listed in the volume 19 catalog.
The Following User Says Thank You to enginenut2 For This Post:
Old 12-30-2013, 06:56:29 PM
I found this engine pictured in "Diesel Engineering Handbook" of 1934 described as a recent F-M development in the diesel engine field to fill a need for more compact engines where lower horsepower is required. The 1945 catalog speaks of them used in marine main and auxiliary service as well as on cranes, power shovels, air compressors, small industrial locomotives, and similar applications. The power rating on both sizes was at 1200 RPM. The multi cylinder engines use individual heads and individual injection pumps operated from the engine camshaft with the rack exposed alongside the 1 piece cylinder block- the sleeves were removable and the pre-chamber like combustion chamber was cast in the head with a passage communicating with the cylinder. Of the 15 different MODELS of engine offered by F-M in 1945 only these two were 4 stroke and I don't recall any earlier 4 stroke engines by F-M.
Old 12-30-2013, 08:05:33 PM
Greg Best Greg Best is offline
Model 36A 4 1/4 10 HP
The Following User Says Thank You to Greg Best For This Post:
Old 12-30-2013, 11:06:29 PM
I stand corrected on the bore for the small engine. 4 1/4 is correct. Don't know where I got the other numbers--it sure wasn't off the chart.
Old 01-17-2014, 04:15:48 PM
Jim McCracken Jim McCracken is offline
I have a FM 36 A 10 HP. I have not run it yet but it is free and
needs only a fuel tank.Mine has a small radiator for cooling.
Does the above engine have a tank for cooling?
By the way,great job on the engine.It looks really nice !
The Following User Says Thank You to Jim McCracken For This Post:
Old 01-17-2014, 05:33:51 PM
Les Layton Les Layton is online now
Hey Jim I have reprinted the instruction manual for the Model 45. I have a small bore ( 3 1/8 ) 0ne That I will dig out for Showtime Les
The Following 2 Users Say Thank You to Les Layton For This Post:
Old 01-17-2014, 07:24:42 PM
loggah loggah is offline
I have a 6 cylinder 36A 5 1/2" sitting in the back yard, 120 H.P. at 1200 R.P.M., it runs some slick !!! thinking about putting it in my lombard tractor chassis, the last lombard built used one. Don
The Following 3 Users Say Thank You to loggah For This Post:
Fairbanks Morse 36 A diesel 10 hp Jim McCracken Vintage Diesel and Oil Stationary Engines 13 12-02-2018 06:38:26 PM
Fairbanks Morse Y Diesel John Cunningham Vintage Diesel and Oil Stationary Engines 19 02-11-2016 04:47:06 PM
Fairbanks Morse Diesel *VIDEO* Fred Van Hook Vintage Diesel and Oil Stationary Engines 8 07-18-2012 12:34:10 AM
Fairbanks MORSE YH Diesel Carl Antique Engine Archives 0 07-29-2001 03:06:30 PM
Fairbanks Morse Y Diesel Carl Antique Engine Archives 10 06-21-2001 12:47:08 AM
