Go Back   SmokStak > SmokStak® Shows, Swaps, Announcements > Shows and Swap Meets > Canada
Canada Shows Swaps Announcements Discussions
Canada
Lanz Bulldog 5006 /6006
this thread has 3 replies and has been viewed 6915 times
Old 03-08-2014, 09:43:58 PM
Albertaberry Albertaberry is offline
Default Lanz Bulldog 5006 /6006
I am working on a Lanz 5006 and it seems the fuel pump is stuck. I can not seem to get it off either, it must be linked inside to a throttle linkage. Anybody have experience on how to take off the pump?
Albertaberry
Old 03-09-2014, 06:03:14 PM
Molinegb Molinegb is offline
Default Re: Lanz Bulldog 5006 /6006
If you post in antique tractor talk you would get more results. I had a D9506 a while back. I sold it to Europe
Old 03-11-2014, 08:12:37 AM
motorenbau motorenbau is offline
Hello
To get the injection pump out you must get the control rod in center position. like in this picture:
If it´s like here it can´t be removed:
Chris
Old 11-05-2014, 08:07:15 PM
I got it all working. There was some rust on the roller. Know hwere I can get a new one? I got one from Delegro but it was the one with the needle bearing and .5 mm too small. Mine does not have the needle bearing but a bushing. tractor working good, but I would rather replace the roller
---------- Post added at 06:07 PM ---------- Previous post was at 06:01 PM ----------
see we have fun with one cylinders. Last weekend in June. Check the other videos by Rainhill.
https://www.youtube.com/watch?v=HGEQlEejmOI
Lanz Value Dale Fye Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 10 04-28-2014 12:06:58 PM
Lanz Bulldog D2216 Pacrat Antique Farm Tractors 8 02-17-2014 05:05:46 PM
Lanz bulldog tractors farmersbase Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 29 01-29-2013 01:49:55 PM
Lanz Bulldog John Davis Hit & Miss Gas Engine Discussion 4 03-14-2011 02:58:04 PM
Lanz Bulldog from the third rijk Brothers Clemens Antique Farm Tractors 8 09-11-2007 02:09:01 PM
