20 HP Reid project part II
this thread has 8 replies and has been viewed 4080 times
Old 01-22-2014, 09:27:52 PM
hitnmis Alex's Avatar
hitnmis Alex hitnmis Alex is offline
Default 20 HP Reid project part II
Had the Reid running for the first time Saturday for 4 hours.also poured babbitt in her that was fun!! Ended up breaking 2 out of 5 main piston rings and put it back together with the 3 good ones I'll try to get a video.posted this weekend.
ID:	185662   Click image for larger version
ID:	185663   Click image for larger version
Old 01-28-2014, 11:00:54 PM
Default Re: 20 HP Reid project part II
Has anyone ever used rubber o rings on the valve instead of the copper rings. Do they go bad THANKS!!!
Old 01-29-2014, 09:49:57 PM
Jerry Turnes Jerry Turnes is offline
I use 3/16" oring on the main valves,last a long time,but is better to use copper on the top and oring on the bottom.i make my own.
Jerry
The Following User Says Thank You to Jerry Turnes For This Post:
Old 01-29-2014, 10:45:06 PM
That explains why I had the top o ring blow out after 4hrs of run time, Ill have to make a copper ring after all. Didn't realize at the time though it blew out I thought it was the valve sticking. But I pulled the charge rod off and spun over the flywheels and the charge piston shot back 6in I knew it wasn't going to run then. This thing does make for a good workout
Old 09-16-2014, 10:22:46 PM
Its official to say that the Reid is now done. Thanks to you guys. Its last run for the season ended at 44 RPM. Not bad. Here's a couple videos thanks to Travis and Rich. Keep in mind I start this by myself with a few secrets
ID:	206124   Click image for larger version
ID:	206125   Click image for larger version
The Following 4 Users Say Thank You to hitnmis Alex For This Post:
Old 09-16-2014, 10:32:14 PM
couple videos
https://www.youtube.com/watch?v=nnmn...ature=youtu.be
https://www.youtube.com/watch?v=Nr9A...ature=youtu.be
The Following 12 Users Say Thank You to hitnmis Alex For This Post:
Old 10-12-2014, 10:01:48 PM
Chuck Hall Chuck Hall is offline
I know your not going to believe this, but it is true. I installed rubber O rings in my 15 hp Reid's transfer valve maybe 3 years ago top and bottom and never had the first problem yet. I removed the old copper O rings and thew them away. I run my Reid all day long at the shows, starts easy and runs beautifully.
Sistersville, WVA no problems. Cumming, GA. no problems. They are a special order neoprene O ring, not the everyday rubber O ring. And compression, I can stand on the flywheel on compression for 30 minutes. May be longer, but my feet get tired. Seriously. I thank Robert Finley for turning me on to them.
The Following 2 Users Say Thank You to Chuck Hall For This Post:
Old 11-06-2014, 10:18:56 AM
Bob Burlison Bob Burlison is offline
The last time you stood on the flywheels you got launched on to the side walk and hit your head on the steps. Thanks Bob from OHIO
Old 11-09-2014, 09:55:54 PM
Uh Oh, The cats out of the bag again Bob (:-)
20 HP Reid project hitnmis Alex Oil Field Engines & Related Equipment 6 01-01-2014 09:45:52 PM
Reid 20 HP project neilert Oil Field Engines & Related Equipment 28 02-25-2013 12:32:46 AM
20 HP Reid Project Steven W Hit & Miss Gas Engine Discussion 17 01-27-2012 10:53:31 PM
Yet another Reid project saved Tom Schoolcraft Oil Field Engines & Related Equipment 7 07-20-2007 05:26:33 PM
25 Hp Reid - New project! Chuck Martin Antique Engine Archives 10 07-07-2004 01:29:39 PM
