Buzz coil or automotive coil
this thread has 3 replies and has been viewed 938 times
Old 03-03-2016, 09:27:37 PM
Bryant Bryant is offline
Default Buzz coil or automotive coil
A guy I work with says that a regular automotive coil will work to run a maytag with no relay. Just the coil. what do you guys think? I don't think it will work.
Old 03-03-2016, 10:18:14 PM
Junkologist's Avatar
Default Re: Buzz coil or automotive coil
It'll work as long as the timer is set up for the proper timing. The spark will happen when the timer contacts break open. Should have a condenser in the circuit also, otherwise arcing at the timer will eat it up.
Mike
SmokStak member #146
Old 03-03-2016, 11:11:16 PM
Kevin Weis Kevin Weis is offline
Also if that's a 12 volt coil you should have 12 volt battery.
Kevin
Old 03-03-2016, 11:11:32 PM
If the engine had a magneto originally the auto coil will work as fine. If it was a buzz coil to start with it will have to be re timed as mentioned. Buzz coils fire when the points close, mags and suto systems fire when the points open. If it was magneto it's possible the points will stay closed for most f the duration, hard on the battery, may overheat the coil. If the engine kills be sure to disconnect the ignition.
How to hook Detroit Coil Co buzz coil - pics Prowl1 Magnetos, Ignition Coils and Spark Plugs 9 04-06-2015 12:09:22 AM
Model T coil or Buzz coil Jerry B Magnetos, Ignition Coils and Spark Plugs 2 11-12-2010 10:41:01 AM
Buzz coil vs. auto coil. Jeremy Hartle Magnetos, Ignition Coils and Spark Plugs 5 12-11-2009 11:50:21 AM
Ignition using automotive coil Joe Bennett Hit & Miss Gas Engine Discussion 6 07-10-2008 09:27:15 PM
Buzz coil or auto coil Don Nelson Antique Engine Archives 5 12-07-2004 06:08:54 AM
