Onan in RV shows error code 11
this thread has 5 replies and has been viewed 1524 times
Old 06-30-2016, 09:18:21 PM
Kingfish Kingfish is offline
Default Onan in RV shows error code 11
I know this is not an RV group but I need help troubleshooting this problem.
Thanks.
RV: 2000 Bounder 39z
Generator: Onan Model 7.5HDKAJ11502F
Serial No. J990999200
Inverter/Charger: Freedom 458 Model 20D (with remote control panel)
Panel Box: PowerTek PDC1020
Background: Generator has always worked perfectly and exercised on a fairly regular basis. Returning home from a trip in the Spring, we ran the generator for 3 hours or so to power the AC, as we normally do in warm weather. Everything worked fine. A couple months passed before another trip was planned and when the generator was tested, it ran a few seconds and died.
Troubleshooting:
(1) The generator will crank and run fine when the breaker on the generator is OFF. If this breaker is ON, the generator will run until the transfer relays kick in, then it immediately dies. The error code is 11, Overcurrent Fault.
(2) My memory is a little fuzzy on this. While preparing for that second trip, the RV was hooked to my 30 amp pedestal. (this pedestal is wired correctly and uses a Progressive EMS-PT30C in line) The RV was hooked up for several days and at least twice, the Freedom 458 gave a "overtemp/overload" red light warning. The PT30C did not give any indication of a problem. After disconnecting and reconnecting the shore power the Freedom 458 seemed to work OK, with no more red light. BUT, I did smell a "faint" smell of hot plastic. No fuses were blown and the smell did not continue. During our second camping trip, the Freedom 458 worked OK.
(2a) This may be unrelated. In an outside bay, I have a Power Guard PG30 push-button breaker. Several times on this camping trip, this breaker would pop, killing AC power to the RV. A simple single-push would reset the breaker and restore power. This happened several times but when it happened, there were no problems indicated on the Progressive PT30C. When we returned, I replaced the breaker.
(3) This week, I decided it was time to fine the problem. I removed the cover from the PowerTek and I find two wires that have melted insulation. These Black and White wires are #10 stranded. One end attached to the two movable contacts on the right hand relay. The other ends attach to a Romex cable that exits the PowerTek box.
(4) The first thing I tried was cutting out the bad sections and making new connections. Cranking the generator resulted in the same problem. Next, I tried breaking the connection, capping off each wire end to take it out of the circuit, then cranking the generator. Same problem, it died.
(5) One thing that I have not done since repairing the burned wires. I have not hooked the RV to shore power to see if there is new melting.
At this point, I don't know how to progress. I have a Fleetwood electrical wiring diagram but it is the most impossible schematic I've ever tried to understand. If anyone has suggestions, I sure can use some help. Maybe someone has had this same problem? Direct replies can be sent to onanproblem at objectmail dot com.
Thanks,
Ed
Old 06-30-2016, 09:57:06 PM
Billy J Shafer's Avatar
Default Re: Onan in RV shows error code 11
Not an RV group but we are a generator group. I would go back to the generator. Turn off the breakers at it. See if it runs ok. If it does then you need to check the wiring to where it hooks up to the RV. And your systems in the RV.
Iam old and need to clean my glasses. Forget the breaker check. Since you already have. But yes you need to check all circuits. I would start at the main breaker box. Check for loose connections and faulty breakers. I would try turning off all breakers. Then plug up to shore power. Have some one standing by to pull the plug. Turn on each breaker. See if anything trips or smells like melting wires. Not the best way to do a test. But the only other way would be to rip up the RV.
Old 07-01-2016, 06:16:51 AM
Gunny Gunny is offline
Sounds to me like you have a problem with something in the RV wiring or electronics. Genset appears to be operating like it should.
The Following User Says Thank You to Gunny For This Post:
Old 07-01-2016, 12:09:21 PM
len k len k is offline
Maybe mouse damage on RV wiring???
Or A/C pump is short cycling??
With melted insulation on 10 gauge and melted plastic smell you the problem is real. I'ld say you definitely have a over load somewhere, or at least a bad connection. Need to find it before it burns up on you.
I don't know RVs but from web the Progressive EMS-PT30C does not appear to be a breaker or current sensor, so not surprising that it did not report any overload.
Old 07-26-2016, 12:36:51 PM
Gary Potts Gary Potts is offline
You need an inverter.
Old 07-29-2016, 11:33:43 AM
hlflorek hlflorek is offline
Are you positive it is a code 11, and not a code 1? Huge difference, and most people have a hard time telling them apart.
Onan Microquiet 4000 Error code 32 Brett021 Onan Generators 16 07-30-2018 09:01:30 PM
Onan 5500 Generator Error Code 58 southernloco Onan Generators 48 02-09-2018 02:04:43 PM
Onan 7MDKBL-5871F error code 2 Spiv Onan Generators 3 11-14-2016 04:28:31 AM
Onan 7HGJAE type B, error 3 code 15 sdetweil Onan Generators 0 09-03-2013 06:07:16 PM
Onan 200DSHAC-6728 Spec: C / Error Code 235 LOW COOLANT LEVEL SupermanSC Onan Generators 10 12-02-2011 09:35:01 AM
