Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Lighting Fixtures, Switch Panels and Meters
Lighting Fixtures, Switch Panels and Meters Antique lighting fixtures, bulbs, switches, meters and controls.
Vintage Vibrator Type Inverter Power Supplies
this thread has 22 replies and has been viewed 3186 times
Old 11-09-2017, 01:52:43 PM
Default Re: Vintage Vibrator Type Inverter Power Supplies
I have a number of these things in different input voltages: 6, 12 110, and either 24 or 32 (I forgot which) volts d.c. output is 110 volts a.c.
They are all made by A.T.R. company, i think. Ive had a little fun playing with them but all of mine are pretty low power rated.
I found the 110vdc to 110 a.c. one in a scrap pile by recognizing the distinctive company emblems and spec tags on it and once in a while I drag out a PE-77 WWII/ Korean war surplus 110vdc generator and run some a.c. stuff with it just because I can.
You can hear the vibrators hum. Not a real barn burner demonstration but a few folks take note.
Old 12-03-2017, 02:27:18 PM
len k len k is offline
Picked up an old 120V vac tube CB radio as a kid. Had a 12V vibrator inverter for car use. Didn't need 12V unit so eventually I trashed it and peeled vibrator can to see what was in side it. 4 large tungstan? contacts, pair on each side. Whole thing wrapped in foam to keep the noise down. Amazing the contacts didn't burn out sooner than they did, with the constant arc heating.
Old 12-11-2017, 01:03:22 AM
dkamp dkamp is offline
eMail NOT Working
The Johnson Messenger (which came in Business bands as well as CB and others) was available with an outboard power amplifier that provided a substantial amplification of output power by using high-level modulation of a pair of 6146B-class-equivalent tubes. The low level modulator ran same tubes I believe.
Rather than a mechanical vibrator, however, my unit (as well as similar power supplies for Heathkit tube rigs up through the late '70's) used a 'rexaxation oscillator) to alternately trigger transistors to the primary windings of a center-tapped step-up transformer... so same idea, but with solid-state germanium passing the current, rather than a mechanical oscillator.
73! KW0D
Dimensions Pure Sine Inverter Powering an inverter directly from the panels 4Strokeguy Solar and Wind Power for Home, Farm & Industry 16 05-19-2015 05:38:25 AM
Sine Wave Inverter & Generator Power Bassplayer1985 Generators & Electric Motors General Discussion 40 10-28-2014 10:30:11 AM
Power inverter questions C-Wade7 Generators & Electric Motors General Discussion 23 08-11-2014 07:19:29 PM
Reducing/Eliminating EMI from Power Inverter Bassplayer1985 Solar and Wind Power for Home, Farm & Industry 11 11-07-2013 01:12:07 AM
