Go Back   SmokStak > SmokStak® Antique Engine Community > Oilers, Lubricators and Grease Cups
Oilers, Lubricators and Grease Cups Discussion about collecting and restoring oilers, lubricators & grease cups.
McCord Force Feed Oiler Cleanup
this thread has 2 replies and has been viewed 1689 times
Old 12-13-2016, 06:45:16 AM
Early Iron Early Iron is offline
Default McCord Force Feed Oiler Cleanup
I am looking for any available info or manual on the setup and adjustment of this oiler. Haven't been inside it yet but may needs some small parts. Have looked on line and have not found much
Thank you.
Old 03-09-2017, 11:50:32 AM
Robt.'s Avatar
Robt. Robt. is offline
Default Re: McCord Force Feed Oiler Cleanup
Here's an advert from 1934. The image will disappear eventually, so I'll just mention that it is described in the ad as a "Class SF" model? Yours look like it might be a bit earlier?
Looks like there are instructions on this navy issue model: https://maritime.org/wish/hipac-oiler.htm
Here's a big ol' drawing of the insides if you ever have a mind to take it apart: Click on it for full size
The Following User Says Thank You to Robt. For This Post:
Old 03-19-2017, 06:47:00 AM
Thank you for taking the time to post this information. Much appreciated. I took mine apart and cleaned it up. It's ready for service again. Took a while to do it right. Lots of small parts.
Manzel Force Feed Lubricators Larry Mix Steam Stationary Engines, Traction Engines 25 06-26-2012 11:30:34 PM
McCord Force Feed Lubricator Brian Nash Farm Antiques and Collectibles 1 01-10-2012 07:23:44 PM
How much pressure should a McCord force feed put out Temple2426 Vintage Diesel and Oil Stationary Engines 6 02-12-2010 08:50:15 PM
McCord oiler? Temple2426 Steam Stationary Engines, Traction Engines 4 08-08-2009 08:50:25 PM
Does anyone know anything about a McCord oiler? Temple2426 Vintage Diesel and Oil Stationary Engines 2 07-30-2009 03:35:17 PM
