Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Lighting Fixtures, Switch Panels and Meters
Lighting Fixtures, Switch Panels and Meters Antique lighting fixtures, bulbs, switches, meters and controls.
Watthour Meter Collectors?
this thread has 62 replies and has been viewed 6205 times
Old 11-01-2018, 07:56:47 AM
OttoEngineMan's Avatar
OttoEngineMan OttoEngineMan is offline
Default Fort Wayne Electric Company Meter
Nice early FWEC Meter in really nice working condition..
ID:	321924   Click image for larger version
ID:	321925   Click image for larger version
The Following 3 Users Say Thank You to OttoEngineMan For This Post:
Old 11-01-2018, 05:06:10 PM
NDmeterman NDmeterman is offline
Default Re: Watthour Meter Collectors?
Originally Posted by OttoEngineMan View Post
It is a USD$40,000.00 meter or more and that is why it got yanked off the bay and ended up in the SW USA..
Quelle surprise.
Old 11-03-2018, 07:48:34 AM
Default 1888 Westinghouse-Shallenberger Ampere Hour Meter
Found this at Portland Show this summer and was quite pleased at the asking price and it was not a "DUPE"..
ID:	322025   Click image for larger version
ID:	322026   Click image for larger version
ID:	322027   Click image for larger version
The Following 2 Users Say Thank You to OttoEngineMan For This Post:
  #44
Old 11-05-2018, 09:30:42 AM
Nice! That's actually beyond the end of the S/N range I have written down for the Shallenberger amp-hour, meaning this was one of the last of this model to roll off the production line, just as Westinghouse was getting under way with production of the Round Type model. (I have had other examples of overlapping S/Ns in my collection, such as a GE I-14 with S/N in the 13 million range and a GE I-16 with S/N in the 12 million range.)
The only hiccup I see is that the two wooden mounting bars seem to be absent from the unit?
Old 12-15-2018, 06:22:46 AM
Rodalco Rodalco is offline
Hi, I am a collector of electro-mechanical watthour meters for 45 years. Have quiet a few meters connected up in our house measuring appliances. I like the Landis & Gyr Maximum Demand meters with the Meccano style gear-trains the best. A lot of meters in my collection are also the more modern ones but still with the disc loadwheel for driving the dials. At the moment designing my generator control panel with CT Ammeters and garden variety kWh meters. Look forward to hear from other meter collectors here as well.
The Following 2 Users Say Thank You to Rodalco For This Post:
  #46
Old 02-08-2019, 08:13:48 AM
The latest addition to my collection - a Ft. Wayne K4, the last US model with a cup-shaped rotor.
Seems someone found about 30 of these in a building slated for demolition, rescued them, and is currently selling them CHEAP on Ebay.
I took it apart for a cleaning (the paint stays in the can for once), and the cover and a slightly bent upper hanger are the only real issues.
The Following 2 Users Say Thank You to NDmeterman For This Post:
  #47
Old 02-08-2019, 09:18:25 AM
Two other meters I recently repaired using parts from a donor meter - a Sangamo JS and a Sangamo LC-2-S. Both are getting surprisingly hard to find anymore.
The Following User Says Thank You to NDmeterman For This Post:
  #48
Old 02-08-2019, 01:07:54 PM
Vanman Vanman is offline
Something I've always wondered... What does the K sub h on the nameplate mean?
Old 02-08-2019, 03:32:52 PM
turtmaster turtmaster is offline
Here is what I picked up a couple of weeks ago, for $10.
ID:	328159   Click image for larger version
The Following User Says Thank You to turtmaster For This Post:
  #50
Old 02-08-2019, 03:34:02 PM
Vanman, meter constant, if I'm correct.
Old 02-09-2019, 05:35:15 AM
Kh is the meter constant
A Kh of 7.2 is very common on modern Class 200 electro mechanical meters.
it means 1 revolution of the disc equals 7.2 Watthours.
Older meters often have a Kh of 3.6 or 1.8.
The Following 3 Users Say Thank You to Rodalco For This Post:
  #52
Old 02-09-2019, 07:40:15 AM
JeffK's Avatar
JeffK JeffK is offline
What kind of meter is on the classified ads now POTENTIAL?
Idle hands are the devils workshop
The Following User Says Thank You to JeffK For This Post:
  #53
Old 02-09-2019, 01:27:07 PM
JeffK: That looks to be a very old Weston voltmeter.
Rodalco: Early US mechanical meters had a "base" Kh of 1/3 (with a few exceptions), based on the rating for a 5A 120V meter, but later, it was changed to 0.6, but now all 'smart' meters apparently have a 1.0 Kh regardless of rating.
Vanman: As Rodalco says, Kh is the watthour constant, the amount of energy measured per revolution of the disk. This is derived from the voltage / current ratings, # of stators, and I WANT to say the design speed and/or disk/register gear ratio figure in there as well. I've got that info around here somewhere, will have to dig for it.
Turtmaster: NICE find! I-16 meters above 10 amps aren't that common. You'll find the Kh marking on the disc near the timing mark.
The Following 4 Users Say Thank You to NDmeterman For This Post:
  #54
Old 02-14-2019, 05:32:07 PM
https://www.youtube.com/watch?v=3bVOZ7vrMAQ
http://watthourmeters.proboards.com/
The Following 2 Users Say Thank You to casertractor For This Post:
  #55
Old 02-14-2019, 10:46:36 PM
radiodoc radiodoc is offline
Ran across this WH meter this past Saturday at a flea market. The owner wanted 40 bucks for it. I told him I really didn't collect these sort of meters but I would think about it. He said he would be back next month. I believe it had type F on it.
Name:	Sangamo Watt Hour Meter F.JPG
The Following 3 Users Say Thank You to radiodoc For This Post:
  #56
Old 02-18-2019, 09:18:00 AM
radiodoc: Those are neat, and I think $40 is a fair price for one.
These were used as rentals by the electric company so people could see how much energy various appliances used. Sangamo and Duncan were the only 2 of the US 'big 4' meter companies to produce these.
The Following 3 Users Say Thank You to NDmeterman For This Post:
  #57
Old 02-18-2019, 01:01:47 PM
NDmeterman the one I saw was a Sangamo. I just may start collecting WH meters to a limited extent. The guy that had it runs the flea market so pretty sure he will be there the first of March. Thanks for your comments.
The Following User Says Thank You to radiodoc For This Post:
  #58
Old 04-12-2019, 03:19:32 AM
Originally Posted by NDmeterman View Post
OttoEngineMan - you lucky duck!
Those Gutmann A meters are VERY tough to find... yours is probably the 5th surviving example I can think of (the others I can think of being in the Itron historical collection, one supposedly in an utility collection, one in Texas, and one in a Columbus-area collection). I know of two major collectors that are still supposedly in the hunt for an example.
If you know of someone looking for one, I do have a duplicate in my museum to let go of...
Old 04-12-2019, 11:23:35 PM
I actually picked up the Sangamo Type F meter I mentioned in post #55 when I returned to the flea market in March. The guy accepted 30 bucks for it. I haven't had time to check it out yet with this being tax season. I did remove the back and look inside and it was very clean.
Old 04-28-2019, 01:31:01 AM
I can think of a certain someone, but have not reached out to that person in years. And I know it would be impossible to get it from point A to point B just because.
Collectors versa non collectors the answers Ronald E. McClellan Hit & Miss Gas Engine Discussion 3 03-12-2016 06:12:12 PM
Any other watthour meter collectors here? NDmeterman Lighting Fixtures, Switch Panels and Meters 14 10-27-2015 02:53:06 AM
Serial number collectors or engine collectors? Tom Gosciminski Hit & Miss Gas Engine Discussion 17 07-14-2010 04:15:40 PM
AC Amp Meter BTPost Generators & Electric Motors General Discussion 6 05-21-2010 06:14:14 PM
