Buzz coil or auto coil
this thread has 5 replies and has been viewed 6701 times
Old 12-06-2004, 11:10:40 PM
Don Nelson Don Nelson is offline
Smile Buzz coil or auto coil
I have a cushman binder should I buy a buzz coil or just use a 6 volt auto coil. It just goes in the battery box, it not like anyone will see it. Any opinions . Don
Old 12-06-2004, 11:21:50 PM
Harry's Avatar
Default Re: Buzz coil or auto coil
It depends upon what type of point setup you have. A standard coil with points and condensor will fire at the time the points open after being closed. A buzz coil will fire at the time that the points close and keep firing until they open again.
Buzz coil ignition can get a bit wild on a two-cycle engine if your points stay closed too long.
http://www.old-engine.com/magbuz.htm
Old 12-06-2004, 11:39:25 PM
D.Smith D.Smith is offline
Don , Harry is right About the points. My 8 hp Cushman uses two buzz coils. D. Smith
Old 12-06-2004, 11:51:17 PM
Junkologist's Avatar
A buzz coil and an automotive coil are not interchangeable. They are for two different kinds of ignition setups. Your engine will have what's called a timer, which is nothing but a set of contacts that close a circuit at the exact point of ignition. When the circuit is closed, the buzz coil is energized and the spark plug fires. The automotive coil is used where ignition points and a condenser are employed. The coil will only fire the spark plug when the points open up and induce high voltage in the secondary coil. The condenser is added in the primary circuit to prevent arcing at the points. Unless you have modern ignition points installed on your engine, you need to get a buzz coil.
Mike
Old 12-07-2004, 05:32:19 AM
David Greenwalt David Greenwalt is offline
I'm not familiar with the binder engine. Is it hit n miss? There's a local fellow here, Sam Morgan, who hooked up a automotive coil and condensor on an Economy engine for another collector. I was watching them do this. He didn't use points, he wired to a bolt connected to the engine, and one on the trip rod. When the one on the trip rod made contact with the one on the engine, he got his spark. Crude, but worked quite effectively. This was on a hit n miss, don't know if it would work on a throttler. David.
Old 12-07-2004, 06:08:54 AM
The timer on a Cushman binder engine is intended for a buzz coil and although it will work with an ignition coil The timing will be more difficult. I would recommend just using the buzz coil it was intended to use. +You can hear the buzz coil when you are trying to start the engine. With an ignition coil you don't know when it is working without a spark tester or a spark gap in the circuit.
Dick
Buzz coil or automotive coil Bryant Hit & Miss Gas Engine Discussion 3 03-03-2016 11:11:32 PM
How to hook Detroit Coil Co buzz coil - pics Prowl1 Magnetos, Ignition Coils and Spark Plugs 9 04-06-2015 12:09:22 AM
Model T coil or Buzz coil Jerry B Magnetos, Ignition Coils and Spark Plugs 2 11-12-2010 10:41:01 AM
Buzz coil vs. auto coil. Jeremy Hartle Magnetos, Ignition Coils and Spark Plugs 5 12-11-2009 11:50:21 AM
BUZZ COIL HELP JEFF B Antique Engine Archives 7 12-10-2001 10:38:05 AM
