Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Lighting Fixtures, Switch Panels and Meters
Lighting Fixtures, Switch Panels and Meters Antique lighting fixtures, bulbs, switches, meters and controls.
Johnson Heat Regulation Electric Switch
this thread has 4 replies and has been viewed 202 times
Old 07-14-2019, 04:05:34 PM
OttoEngineMan's Avatar
OttoEngineMan OttoEngineMan is offline
Default Johnson Heat Regulation Electric Switch
I am not exactly sure what this is, but I assume something to do with dampening ...? This is quite large and weights about 30LBS..18 inches from top to bottom and 12 inches wide...
The Following 2 Users Say Thank You to OttoEngineMan For This Post:
Old 07-14-2019, 04:35:29 PM
Vanman Vanman is offline
Default Re: Johnson Heat Regulation Electric Switch
It sort of looks like a big thermostatically controlled switch? Definitely some kind of switch...
Keith
Old 07-14-2019, 05:02:32 PM
mmcdonald mmcdonald is offline
Very cool, so I did some searching. Appears to be from late 1800's originally(I don't know how many years they were made). Used to control heating mainly by operating solenoid type valves as best as I can gather. Don't know how collectible it is but I bet there's not many floating around. Thanks.
PS if you want to find out more search the internet for "johnson system of heat regulation" in parenthesis.
info@mcdonaldcarb.com
The Following User Says Thank You to mmcdonald For This Post:
Old 07-14-2019, 05:20:56 PM
I have had it for many of years and knew it was early and unusual so i bought it now matter how collectible it is to others. I have a extremely good eye for early things and this just caught my eye at The Portland Gas Engine Show many a years ago... I also thought late 1800's or very early 1900's..
---------- Post added at 05:20:56 PM ---------- Previous post was at 05:19:52 PM ----------
Keith
I know it is early and unusual and thats all I know...!
Old 07-15-2019, 06:08:32 AM
GeneratorGus's Avatar
GeneratorGus GeneratorGus is offline
Just a guess, possibly a very early circuit breaker. There is something in the construction that reminds me of these large ITE breakers I picked up a long time ago. These are much later vintage, but...
Name:	1250 Amp Breaker.jpg
ID:	339099   Click image for larger version
Name:	1250 close.jpg
ID:	339100   Click image for larger version
Name:	1250 closer.jpg
The Following 3 Users Say Thank You to GeneratorGus For This Post:
Heat Pumps + Electric Heat Strips billinjax Honda, Yamaha, Kawasaki, Isuszu Generators 6 01-04-2018 03:01:08 PM
Electric Tankless Hot Water Heaters and pre-Heaters for Drinking + Baseboard Heat? 1215 Solar and Wind Power for Home, Farm & Industry 25 04-10-2016 08:47:21 AM
Switch air compressor from gas to electric snowshoveler Generators & Electric Motors General Discussion 6 02-06-2016 12:06:51 AM
Johnson Utilimotor Kill Switch? kleinkaliber Small Air Cooled Gasoline Engines 0 08-26-2015 08:14:57 PM
ONAN MDJE exhaust heat switch rgano Onan Generators 1 10-20-2012 09:06:44 AM
